Question about Sony DVP-NS67P DVD Player
My dvd is working for about 10 minutes than it shout down completely. I have to push on Power, than to wait until it reads the dvd, it's starting all over again and it's working again for a few minutes until the power goes off again. It went like this for about 5 times and now it's not working at all. Is this a problem that i can fix somehow?
    Habit-Forming:
  • Sony Expert
  • 161 Answers
There is a problum in power supply most comen problum is main filter capaster if you can chang the main filter capaster then your dvd is ok other wise go to your nearst sony service centre & fix this problum
Posted on Aug 20, 2010
No power at all. pluged into wall.i push bucket switch and try to start up,nothing.no power
To troubleshoot the problem: First start with the wall outlet. Is there still power to it? If not a circuit breaker in your homes breaker panel may have tripped. Is there a lose wire connection in the outlet or is the outlet damaged inside? If all of these things check out OK, try plugging the unit into another outlet that's on a different circuit.
Other causes:
The bucket is full. Unit shouts off completely when this occurs.
The bucket is not installed properly. Remve bucket and reinstall it "squarely" from top to bottom
into the bucket holder.
If the ambient room temperature is 112 degrees F or lower than 32 degrees F, the unit will shout down to protect the compressor. Wait 3 minutes and then restart the unit.
If all of the above troubleshooting fails to resolve the problem. Call Haier Customer Service
1-877-337-3639.
I hope this has helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier HDN655E Dehumidifier
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
My HP photosmart c8180 get's error 83c00020 at startup.
This same error code has been frustating me for weeks. After reading to push this... wait... unplug... wait... then replug, on several sites, I started to make up my own sequence. The following sequence worked for me, maybe it will work for you.
Push "red-eye removal" and the "power" buttons at the same time, for a couple seconds. The "hp" comes on the screen with the colored line at the bottom. The printer starts making all kinds of noise. Follow the promps on the screen. After 10-15 minutes the screen informed me that the "Scheduled Maintenance Complete" and now the printer works. Crazy!
Mike C
Feb 28, 2011 | Office Equipment & Supplies
It is stuck on start up screen
Remove the battery - wait about 10 minutes - put it back in ... Try to power up. If it comes on .... Presto ... instant fix. If it doesn't, remove the battery again - wait about 10 minutes - put it back in. Put it on the charger until charge is complete. Try again ... if it works - Presto - delayed fix. If it doesn't, it is time for you to call your service provider for a fix.
Thanks for your question
Feb 03, 2011 | Sony Ericsson Cell Phones
My Samsung HC-p4363w have no pic or sound but the power red light is on
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
-please rate me. Thanks and good luck.
Nov 20, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Code error 021 not in book inforation codes
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax (and cross fingers)
Jan 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Sony DVP-NS67P DVD Player Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
