Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
What is the process for replacing the drum bearings for my thin twin LT5000XSN2. Need step by step. Sounds like is about to fall apart. I am very good at fixing most things.
  • Whirlpool Master
  • 3,361 Answers
Copy and paste this factory service manual for the Thin Twin.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
Posted on Aug 19, 2010
  • 4,066 Answers
The problem is usually not the bearings at all but the felt guides on the front of the drum. The felt wears off and then makes lots of noise. You can access this part by removing the front along with the door. Listen close with the button in and door open to see if the noise is coming from the front or rear.
Washer spin loud noise
Front load machine......
a) When not on cycle.... Unplug the machine from power. Open the door and give a spin to the drum from your hand.
a1) Does it make a cluck cluck noise.... Your drum bearing or inner drum bracket is gone.... Very expensive repair. Need to buy a new machine unless you have warranty left at least for the part.....
Apr 24, 2015 | Whirlpool Thin Twin Washer and Electric...
Drum inside washing machine seems to come loose..making a really loud banging noise. Whats the best way to fix this.. Whirlpool Thin Twin
Might be a spring or the skate plate out of alignment.
Thin twin service manual is in this apartment series service manual:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZDgzODI5MjYtMWNmYS00MWZkLTk0ODEtNjM3MTIyYzVmZWVl&hl=en
Sep 18, 2011 | Whirlpool LTE5243D Top Load Stacked...
How do you take out the rear drums out of a 2002 ford focus zx3 i took out the four nuts in the middle of drum and still didnt come out
You may have to loosen the brake shoes. And also "bang" on the drum with a small sledge hammer. Generally the will be rusted on and may require a good amount of force.
Sep 05, 2010 | 2000 Ford Focus
My maytag dryer is making horrible squealing and scaping sounds. What is probable problem and how do I fix it? I have dryer out but see no access to front panel.
hi the noise you hear is going to be the drum bearing it sounds like it has collapsed and will need replacing if your is the model shown in the picture then its the back of the dryer you need to get to you should then see the center of the drum and this is where the bearing is located its not an easy job to replace and if any damage has been done to the part where the bearing runs on the drum then this would mean any new bearing you put in would also not last very long so if their are scratch marks or sharp edges then this means the drum will also need replacing.
if you remove the back and take the drive belt off then try turning the drum with the belt off you should feel its a bit tight or you should feel it grinding, you could actually try doing that now open the door and try turning the drum by hand and see if you can feel the grinding.
the bearing will need replacing and possibly the drum depending on how much damage has been done to the drum due to the bearing collapsing,
if your doing the job yourself then you may need special pullers to pull the bearing casing off as the chances are this has been welded to the spline due to the heat caused by the bearing falling apart, its not an easy job to do but it can be done.
May 23, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer is squeaking while in operation
Rear drum bearing may need lubrication or replacement. This bearing is located on the back of the drum and requires taking the washer housing apart to get to it. They sell a high temperature lubricant if that is all that is needed, but a small bit of automotive grease or bearing oil will work well. You may have to buy bearing replacement parts ie a drum rear bearing and post kit or a bearing replacement kit. You will need better than average skills to do this yourself. As soon as you take off the front panel the drum will have no support and will drop forward. Try not to let the drum belt to become to loose or the belt retention wheel may become disengaged and the belt will fall off. Make sure you unplug the dryer before taking ANYTHING apart.
Jan 14, 2010 | GE Dryers
I have a 93 Chrysler Town &Country mini-van yesterday on the hwy I thought I felt a wobble when driving but nothing was visibly wrong. Now I noticed a dragging or grinding sound and this time when I...
It shouldn't fall apart if you remove the tire and if it does you should be thankful you didn't drive it to the shop, jack that side of the vehicle up and then rock the tire from the top and bottom, sounds like you may have a bad wheel bearing, the grinding could be the bearing or it could be the rear drum dragging on the brakes or both. If the wheel has excessive wobble when rocked it is probably the wheel bearing.
Dec 03, 2009 | 1993 Chrysler Town & Country
Heavy thumping noise with the turning of the drum
sounds like your rear bearing is bad, look in the rear center of your drum. for a crome pop out plug. Pop it out with a flat srew driver
there will be a nut that holds the drum in. take that nut off and you can lift the drum right out the front of your dryer. the front cover pops off after you take out the 2 screws from the lower front panel.
Aug 08, 2009 | Dryers
WHIRLPOOL LT5000XSN2 DRYER HOW TO REMOVE DRUM TO REPLACE SEAL?
hello Maryann,
I would like to tell you but its best to know how to take the machine apart,
The drum seal is located in front of drum, which means you need to take front of dryer cover off
Jun 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
359 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
