Question about NEC Computers & Internet
I can't find driver Windows7 64 bit driver for NEC Multisync FE991 monitor
informatica
  • 1114 Answers
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
budmrtn
  • 11361 Answers
SOURCE: NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 15, 2010
SOURCE: NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
Posted on Feb 16, 2010
SOURCE: screen and colors too bright
Sorry to say, but I'm having the same problem. If it doesn't change when you press the Fn key and the hollow/right arrow sunshine, then, I doubt there's anything you can do.
Posted on Feb 18, 2011
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
I need drivers for an NEC MultiSync LCD 1700M+
Call at 0800-756-2971(TOLL FREE) for any Drivers i can also provide drivers support
Feb 15, 2013 | NEC Computers & Internet
The resolution notifier keeps popping up (NEC multisync 1740 CX) and I am unable to turn it off.
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Oct 13, 2009 | NEC MultiSync 1940CX 19" LCD Monitor
Need a user's manual for a NEC EA261WM monitor, but can't seem to find one on the web.
You can download from NEC support pages:
MultiSync EA261WM-BK User's Manual
user manual
user manual
user manual
Sep 18, 2009 | Computers & Internet
Touch system not working NEC multisync 1550v
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Nov 06, 2008 | Computers & Internet
Driver for NEC Multisync XE21
Normally if you set the refresh rate to match what the specs are (mentioed above), it should go you working.
Jun 07, 2008 | NEC MultiSync XE17 (White) 17 in.CRT...
Nec lcd1560v+
http://www.necus.com/support/ go down to where it shows drivers and software, choose NEC MultiSync LCD ...
Download the NEC LCD monitor installer and run it, NEC shows your monitor supported by this software. :)
Feb 11, 2008 | Gateway FPD2275W LCD Monitor
NEC P1250+ hisses and scrren blips intermittently
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Sep 19, 2007 | NEC MultiSync P1250 Plus (White) 21" CRT...
Computers & Internet Logo
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
