Question about KitchenAid KGST307 Gas Kitchen Range
Buttons don't work [7, 9 & Start]
Some buttons including Start do nothing. Took control panel off & cleaned ribbon cable contacts etc. Still won't work. Do you think the problem is in the "glass console panel" or the "control panel" ?? Thank you
    Scholar:
  • 58 Answers
Make sure the unit is not control locked, usually holding start for 5 seconds activates this, most kitchenaids contain a lock symbol on control panel so hold that if you have it.
if its not control locked and not in sabbath mode (sometimes this is a SAB or to some looks like 5A6 on control panel) holding clock pad for 5 seconds activates and deactivates this same as start does with control lock
when you order the part you want to replace the part called Clock AKA PCB AKA ECB, these are the three most common names, the control panel is the decorative cover
Posted on May 02, 2008
Touch Screen Not Working. Have cleaned the ribbon cable contacts and still the screen lights up showing the buttons but nothing on the touch pad works. If not the ribbon cable being dirty, I guess i
Most of the time the panel buttons stop working because grease gets between the outer panel and the contacts underneath. Disassemble the door and if you need to carefully peel back the outer panel, use some paper towels to remove the heavy grease, then using a Q-tip and some rubbing alcohol clean the back of the panel and the surface contacts on the board, then re-assemble.
Dec 26, 2014 | In Microwave Ovens
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Control panel buttons not working
if your sistem ( has batteries, replace by new ones, but clean the contacts batteries from dirty, oxide, etc use contacts cleaner and tight the spring with pliers)>
2) tight the ribbon cable inside the display board.
3) tight and clean the upper and lower connector from display.
4) adjust the REED swtich. see the diagram attached.
Oct 18, 2013 | Precor 9.21 Treadmill
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
Buttons light up but when pressing buttons to start...nothing. would there be a battery that needs replacing?
1) replace batteries under the display board, clean the contacts with contacts cleaner.
2) adjust the REED switch, clean it and tight the wires connector.
3) tight the ribbon cable from keypads, clean it, tight the wires connector from display board vs lower board.
God bless you
Jul 20, 2012 | Proform Sport 1000 Folding Treadmill...
Model MDBTT60AW quit working - control panel has no effect. Lights will sometimes come on - all of them at once, but the buttons do nothing. Thanks for any help I can get. David Meek
The front touchpad panel uses a ribbon cable to connect the buttons and lightd to the electronic control unit. This ribbon cable tends to corrode atvthevpointvwhere it passes through the door to the control unit. You will see a brownish rust on the ribbon cable. A new control panel appears to e around $135.
Jan 23, 2011 | Maytag Dishwashers
Some Ovens Control Buttons Don't Work - Frigidaire PGLEF385B
although you cannot see damage / the when the buttons do not respond. its possible that membrain is damaged or the eoc ( clock ) is not able to receive signals from the touch pad .. the clock will have to be replaced . list price for clock is 171.00 and includes membrain ( touchpad) .. hope this will help mm
Dec 03, 2009 | Frigidaire FEF376 Electric Kitchen Range
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Jun 16, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Canon ir 400s
Try cleaning the control panel and all the buttons/keys. If problem persists, try banging the keys individually. The control panel will not respond if any of the keys are stuck down.
Sep 15, 2007 | Toshiba e-Studio 205 Copier
Camera control buttons do not work, stop, play etc
your flexible control panel cable may have torn ( from loading and unloading ) - if there are leds ? in yours , the replacement part often does not have them ( many users miss them ) ; get an estimate , before committing to repairs on a 7 year old camera ( starts at $ 50 plus parts and shipping , here in puerto rico ) ;
Jun 09, 2007 | Sony Handycam DCR-TRV310 Digital Camcorder
KitchenAid KGST307 Gas Kitchen Range Logo
672 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
