Question about Dell Optiplex GX240/GX260/GX270 SFF Front Panel 7M501 Floppy Drive
My gx260 shows as having A and a B floppy drive and it only has one drive fitted. The cable is the original with a single connection.
  • gm0onx Aug 22, 2010
    Thanks for the tip, for some reason the USB memory stick I have connected has partitioned itself into an E and B drive. Its not supposed to be bootable but there you have it.
    Novelist:
  • 159 Answers
Check your BIOS settings (both bootable CD's and bootable USB memory sticks can appear to older BIOS as Floppy drive's :-) )
Posted on Aug 22, 2010
When started system show . 0seek driv failur
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Dell OptiPlex GX260 PC Desktop
I have a technics sx ex35 organ with a broken floppy diskdrive. Where can I purchase a new drive and how much will it cost me?
It is near impossible to get parts for some of the Technics things... Find a source dealling in scrap computer recycling... take your drive there and see if you can find some that will fit connection wise and mechanically and just try them...
IF your floppy is one of the old 720K drives, those are almost non-existent... You can tell if you use floppies disk that have two holes at the two corners instead of a single one those will use the 1.4Mb conventional rather than those 720K ones...
SOMETIMES you may have to jumper configuration pins to work with these synths...
Nov 15, 2010 | Music
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
I'm having trouble adding a secondary older hard drive in my ET1831-07. Do I make it slave and do I use the power plug labled "PC"?
if it is on the same cable as the original hard drive, you must ensure that the original drive is jumper set to master, not single, and the new drive is set to slave. if the connector is a 4 pin molex cable, and it will fit easily in the power connector, it will power your hard drive.
Jan 20, 2010 | E-Machines Computers & Internet
How is the power supply removeddell gx260
Unplug computer and then press power button for 5 seconds to drain capacitors. You'll need to remove the case screws and case to get to power supply. From the back, you'll see smaller screws near the fan output vent of the power supply. All screws are phillips #2. Dell sometimes uses special clips that you have to press or pull to release objects, but may not for power supply. You'll have to disconnect all power cables from all internal devices including hard drives, CD/DVD drives, floppy drives, motherboard and any power assisted graphics cards. There may be additional chassis screws holding power supply to chassis. If you are replacing power supply, be sure new one is of at least same wattage as the original. New supply should match the same configuration as the old one and have the same style motherboard connector. Name brands like Compaq and Dell have used supplys that are specific to their PC lines. But, you should still be able to find OEM replacements. Looking for a replacement, try www.pricewatch.com.
Oct 05, 2009 | Dell OptiPlex GX260 PC Desktop
Dell GX260
You need to change the boot order in the bios of the computer. It is also called the setup. When you turn the computer on, in the top right hand corner of your screen you will see F2-Setup F12-boot menu. Select F2 and when you get into the bios go through the options until you find "boot order" or just "boot". That will show what devices your computer will use, and in what order, to boot up. If the floppy is below the main hard drive then it won't work unless the hard drive is defective. Move the floppy to the top of the list, exit saving changes, and it will now check the floppy first.
Dec 11, 2008 | Dell OptiPlex GX260 PC Desktop
Floppy error 40
check if the cable is in the correct way stripe toward the power plug
Jul 17, 2008 | E-Machines eMachines Desktop PC
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
P4VMM2 - ???
disconnect drive 'A' floppy drive and see if it will boot up without it connected. It may be that the floppy is faulty if you know the ide cable is on the correct way round, as your pc may be set to halt on all errors
Apr 09, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
101 people viewed this question
Alun Cox
