Question about HP LaserJet 1200 Printer
I have an HP 1200 laserjet printer. I get a white line across every picture. How do I get rid of it?
  • dave84 Aug 19, 2010
    Hello!
    I read the link you sent. My first reaction was it seems to narrow down the possibility to a defective cartridge or a dirty and/or defective printer. Is there a 3rd possibility? I cleaned the printer everywhere that was accessible. Since the problem only started after I changed the cartridge (and it was not an OEM cartridge), I assume the problem is in the cartridge. However, the only way to find out for sure is to spend $70 on a new official HP cartridge and see if the problem goes away. If it's an old and cranky printer, I'd rather spend the $70 as part payment on a new printer.
    I guess then, my question is not what could possibly be wrong, but what is probably wrong.
    If it's the cartridge, is there some way to clean it (I can't seem to make the green cylinder rotate,even though there's a gear on one end) or should I just toss it out, even though it's brand new.
    If it's the machine, is there something I should clean or adjust (like a "corona wire" whatever that is). Maybe this question is more philosophical than mechanical, but I would appreciate any wisdom you've acquired.
    Thank you!
    Dave Goldin
  • HP Master
  • 6,993 Answers
Check the below link for troubleshooting tips n how to solve the problem:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl70340
Read all the information on the page.
Good luck.
Posted on Aug 19, 2010
  • Walesarumi
    Walesarumi Aug 19, 2010
    Remove the toner shake it, fix it back into the printer and try to print again. Check it this will make any difference.
    Take care.
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
Hp 1200 problem printing block black
sound like a toner problem, try shaking the toner a bit.
Remove toner cartridge, then shake it left to right and up and down(without hurting yourself) then replace the toner and then try again.
If its still giving problem then either the drum is bad or cartridge is defective, try another cartridge to be sure. try to avoid spraying air in the printer as toner might adhere to the printhead causing more problems use a vacuum.
Good luck. Wish they have a option to post picture of problem area's on these post its best to see the problem or a sample of the problem.
Feb 14, 2013 | HP LaserJet 1200 Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
I get a vertical black line on my printout, from my HP 1200 laserjet. Can you help?
May b your printer needs some servicing.
The black line may be caused by a faulty or used fusing film or fuser roller.
Mar 15, 2010 | HP LaserJet 1200 Printer
Have solid blk powder lines across printed pages. What do I need to clean ?
Try a different toner cartridge if you have one available. 90% or more of the time this is going to be a cartridge issue.
Good Luck
Nov 18, 2009 | HP LaserJet 1200 Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 1200 Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
