Question about NorStar M7310 Corded Phone
My internal Extension
I am in an office with multiple phones setup. We are trying to call one of our extensions internally, but have no idea what the extension numbers is. How can i get this number? When I dial out, call displays only show our generic number. Any ideas?
  • Anonymous Mar 17, 2014
    how do i change the internal extension number of a function key
  • 326 Answers
Try
feature
the *0
then if you press the last button on the right coloum (line 10)
mine shows up when i try this
hope it helps
Posted on May 05, 2008
I have 1 extension that will not go to voice mail. I have tried the *713 and a 2 digit number between 00 and 99 and it still just rings endlessly. When I make an inner office call to this ext... it picks...
What happens when you TRANSFER an outside call to that extension? If that works, you have Intercept issues which is handled with programming. If it still does not transfer, you have CF issues, started by a *710x command for both internal and outside calls.
Carl
Aug 11, 2010 | Panasonic KX-T7633 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
May 21, 2009 | Nortel T7316E 2-Line Corded Phone
Switch unable to transfer calls to extension
Sounds like the station is in do not disturb mode.Internal, external and transfered calls do not ring but the station can still make calls. there should be a lit button on the set maybe marked do not disturb or DND. press the button again to turn the led off. hope that helps
Mar 24, 2009 | Toshiba DKT-2010H Corded Phone
Set not ringing
When you say you are the one responsible for the programming, are you referring to programming the "physical phone" or the PBX and line cards and system functionality?
You should have an extension on your phone. Has that extension for example 222 been translated at the PBX to ring on a direct number -> (xxx) 555-1222
Or by what you are describing, you are more looking at having "shared lines" that ring in multiple locations simultaneously, and once picked up somewhere a "line lock" should be in place?
Aug 13, 2008 | NorStar M7310 Corded Phone
Internal intercom
If the person you are trying to reach is speaking to another internal extension, none of the outside lines will show in use. If their phone is not Call-Forwarded to any other extension (i.e. second extension or VM), you will get a busy.
Feb 06, 2008 | NEC Electra Professional ETW-16DC-2
Ring back
If you call the extension internally, does it just ring no answer?
You will need to go into programming:
At extension 10 or 11:
Feature 00
Left interom twice.
#310
enter the extension you are having a problem with
pres the 1 button
the display will say 1-Assigned
Feature 00 to exit.
Jan 02, 2008 | Lucent PARTNER18 Corded Phone
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NorStar M7310 Corded Phone Logo
96 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
