Hello, i have a samsung netbook, and i switched it on today and it says that i cannot connect cause theres no connection sign,and i wanna no how u get it back cause it looks like its been wiped off my laptop, .. PLEASE HELP !!!!
    President:
  • 1,768 Answers
.Log into router. Using either 192.168.0.1 ot 192.168.1.1 in a browser window that is ( internet Explorer or firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set
up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to
access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Posted on Aug 19, 2010
Internet Explorer 8
Are you using a router? Do you use cable internet? Try connecting directly the cable directly into your netbook. If you have internet access then the issue may be with your router.
Aug 24, 2012 | Samsung Computers & Internet
My notebook was working fine the day before, and fully charged! today, while attempting to switch it on by sliding the power switch, it won't happen! it is not switching on! please suggest how i may f
Probable cause. Plastic on/off power switch slider is cracked and cannot operate actual power switch. Need to disassemble netbook to gain access to switch. Superglue may provide temp solution but best option to contact Samsung for part.
Dec 22, 2011 | Samsung N150 (36725723009) Netbook
Switched on my samsung n150 plus netbook and the screen is black and says operating system not fond
Either the Operating System got corrupted, the Hard drive connection got loose, or the Hard Drive has failed. Remove the Hard Drive then put it back in to make sure connection is secure. Please refer to this link for step-by-step instructions - click here
Hope this help. Goodluck!
Mar 27, 2011 | Samsung N150 (36725723009) Netbook
I have wireless connection but can't connect to the internet. I can however connect my ethernet cord in and get on the internet that way. What could be the problem
you may wanna check if the wireless switch is on or off (usually located on the front of the pc and it needs to be toggle on the right side)..if not work you may wanna try to update the wifi driver under device manager..
hope this helps :D
Mar 23, 2011 | Sylvania G-Netbook
I have a Samsung N210 plus netbook, how do I connect it to my Sony Bravia TV please? I do not have a HDMI cable just a Monitor cable!
If your TV is the KDL-40S2000 as listed above then you will have a PC monitor socket on the back of your TV (outlined in red):
To connect to your PC:
1. Switch the TV to STANDBY or OFF
2. Connect one end of the monitor cable to your TV and the other to your Netbook
3. Switch on the TV - and startup the Netbook
4. Switch the TV to the PC input mode . . .
Feb 14, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hello, my samsung n 120 which is 1 yr old-the screen started flickering with multi colors, can u help?
hi,
if you could open your netbook. here is what you can do, check on the flex or ribbon connector that connects your LCD to the mainboard. Remove it and check for defects or dirt on the terminal. Check also if the connection is not loose. Replace it securely to the slot. If still that is the problem, then most probably a flex or ribbon problem or the LCD itself (hope not).
View this video below on how to disassemble your netbook. Although different unit but still the concept is the same.
Don't forget to rate me. Thanks..
Regards,
John
Jan 14, 2011 | Samsung N120-12GBK Netbook
Do i need to buy a external modem for my netbook to go online
First you need to check if your netbook has a wireless switch, it used to be in front or by the side or in front of the laptop, if it does, all you need to do is to turn it on, and if there is a wireless network around, then you will be able to connect to the internet.
You can also the control panel to see if the netbook has a wireless switch and where it is located on the netbook, and that will simply tell if you do have wireless service on your netbook.
From the sides of the netbook, there is an internet port, if there is no wireless switch, then you can connect any local connection available in the internet port that is by the side of the netbook.
But you need to ensure there is a local connection somewhere, and the router is working correctly, then you can use the local cable connection, but if there is none, then you will have to buy an external modem for the netbook to go online.
I hope this helps.
Dec 21, 2010 | Sylvania G-Netbook
Is there a way to switch from wireless to wired internet on asamsung np-n310 netbook.
Yes I looked up the specs of your netbook and it shows you have an ethernet port but there is no phone modem. Just disable your wireless connection and plug in your wired connection.
To disable your connection open Network Connections in Control Panel and right click your wireless network (you enable it the same way).
Here is the link for your netbook specs http://www.samsung.com/ca/consumer/office/mobile-computing/netbook/NP-N310-JA01CA/index.idx?pagetype=prd_detail&tab=spec&fullspec=F
Jan 13, 2010 | Samsung N310-13GBK (NPN310KA05US) Netbook
Samsung nc10 netbook will not connect wireless network
I know you posted this a long time ago (5 or 6 months), but just for future reference with other having this same problem or if you just gave up on connecting it wirelessly, here's the scoop. The Samsung NC10 netbook will not connect wirelessly and will sometimes tell you to make sure the the Wireless Switch is "On". However, there's no indication of where this magic switch is. I looked all over my keyboard, the casing, etc. I feel foolish now, but at the time I thought surely there existed an obvious switch. NOPE! The switch is located in "Change Network Settings" or something like that, sorry I don't have the computer right in front of me (I prefer my MacBook). In the window that opens, first thing you will see is your wireless network card listed and a button next to it that says "Configure". Click the "Configure" button and when the window changes you will be able to switch your wireless connection from "Wireless Off" to "Wireless On".
Dec 24, 2009 | Samsung Tablets & eReaders
WhatisnecessarytoconnectmySamsungNC10netbooktoalandline?
Hello
Thank you for using
FixYa for your problem
Some Computer store sell and USB to modem adapter, this will then allow you to use the netbook on the landline
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Samsung NC10-14GW Notebook
Computers & Internet Logo
David Payne
David Payne
