Question about Sharp AF-S120FX Air Conditioner
MY SHARP AF120FX ALSO DOESNT DRAIN AND THERE APPEARS TO BE NO DRAIN HOLE AND THE UNIT HAS ALWAYS BEEN ON AN ANGLE. THE UNIT FILLED WITH BLACK MOLD ON THE STYRO FOAM INSIDE TOP OF UNIT SO I SPRAYED IT WITH BLEACH N RINSED W SPRAYING WARM WATER INSIDE, THAT IS ALL IN THERE NOW AS WELL N NOT DRAINING... WHY DOESNT IT HAVE A DRAIN N HOW DO I GET WATER OUT?
  • Sharp Master
  • 43,501 Answers
Many newer units are made to retain the water and splash it onto the condenser coil... Clorox in the water will kill the mold and not hurt anything... You can carefully drill a hole if you want..
heatman101
Asker's Testimonial " good knowledge, very helpful thank you " - rubicon1952
Posted on Aug 19, 2010
MY SHARP AF120FX ALSO DOESNT DRAIN AND THERE - ddd4f9b7-c1d0-4f6b-8fc3-09d9f8e10662.jpgI don't believe spaying Clorox I don't think it is going to resolve it. I tried that and after a few days the smell was back. So I disassembled the air conditioner . The fan blade that draws the air in from the house is incased in styrofoam. And was full of black mold. You will have to take it apart a clean it. I will try to attach a picture. Please note that I have removed the top half of the fan enclosure.
Posted on Sep 22, 2013
Why is it not collecting water in container?what can i do? do i need the manual?
oohn ive seen this before in some units especally on ones that are in heavy use (lots of water to remove) the drain hole inside unit drain gets stopped up with black mold (wet enviroment it grows quite well) unplug unit and some minor dissasembly of the outter case and it soon becomes obvious what the problem be , i have been somewhat sucessfull with a mild laundry bleach in a trigger sprayer to kill mold and use a pencil to poke open drain holes
I'LL bet thats your problem
Oct 20, 2014 | Dehumidifiers
Why does the tub not drain completely after the end of the cycle? This creates extensive mold and odor problems.
The pump is partially blocked or restricted that empties the machine. There is usually an access panel so you can check for debris, buttons, coins, hairgrips etc in the pump. Be ready to catch the water if you pull off a hose.. The alternative is the pump motor is running slowly due to dry bearing or corrosion. Both could prevent the pump from fully emptying the system.
Aug 05, 2014 | Maytag Neptune MAH5500B Front Load Washer
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
Water on floorboards when ac runs
Look under the passanger side of the car,There should be a drain hose next to the firewall thats sticks down,It should be a black hose or tube that is cut at an angle on the end,pinch the bottom of the hose and see if warter darins out of it,if it does use small wire to clean inside of hose(evaporator hose)
Jul 23, 2012 | 2003 Pontiac Aztek
The styrofoam inside the unit is covered in black mold. I was wondering what i should do if anything.
Any mold in any part of the unit is not good, especially if its in the Styrofoam, Styrofoam has pores and hides the mold spores well, it would be dangerous to actually run the unit with mold spores as it can travel inside the house. Unfortunately companies that make these units don't make these units mold proof, why should they? that's how they make their money. I have three units, one has always given me problems with mold. It always comes back. The other two are always clean. My best advice, get rid of the unit and get another one or get a free estimate on Central air and heat. Mold is very dangerous and is not worth the risk, it can cause a number of medical issues.
Aug 16, 2011 | Haier HWR08XC7 Air Conditioner
The water doesn't drain through the site to which I attached the hose. Instead it drains through a quarter inch hole (which appears to be a manufaactured hole, not a crack or break)to the right of...
It sounds like the unit should have came with a plug for the hole. You can probably obtain a plug from a home improvement or hardware store or even improvise one yourself. Also, make sure the unit is pitched so that the water actually runs towards the hose.
Jun 26, 2011 | Soleus Dehumidifiers
My Mitsubishi air conditioner has started to leak heaps of water from the side of the unit. It would appear to be something like a blocked drainage system, but I do not know how to open the unit to clean...
find the drain hole in the rear of the unit and take a piece of wire and rat the drain hole out, its got mold growing inside and plugging the drain
Oct 25, 2009 | Heating & Cooling
Mold in gasket
sorry to hear it'
your right that the beoot is stained but the active mold can be fixed first make sure your boot drain is clear, its a small hole at the botom of the grey "boot"
next buy some dish detergent crystals
one empty load with 1 cup of the dish detergent
this should kill you active molds
now always dry the boot between loads with a rag or towel
its a pain but it will eliminate the problem
make sure the drazin is clear every laod
Oct 07, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
FRT21HR6AB3 SELF DEFROTING DRAIN APPEARS PLUGGED'' BOTH FRI AND FREEZE UNIT WORK BUT WATER FROM FREEZER DEFORST RUNS INTO FRG UNIT. HOW DO I UNSTOP
either pour hot water into hole or i have always removed rear wall. your drain hole is located under the evaporator. take long metal hanger and poke out restriction. very common problem
Jun 21, 2009 | Refrigerators
AC accumulating water, not draining properly????
For some reason, newer AC window units no longer are made with a fluid drain. I think the intent is for the unit to be mounted at a sufficient angle (it MUST be angled back so the fluid drains toward the back of the unit) that the rear (outside) fan kicks the water over the condenser coil and gets rid of it that way, it also increases cooling ability slightly in this manner by misting the condenser coil. I would suggest increasing the angle of the back tilt by adding a 2x4 maybe under the unit to allow it to tilt? Alternately, you can drill a hole in the rear corner of the unit to drain fluid, but this is not recommended for several reasons...
1) It will usually cause rust to start at the drill hole.
2) you could accidentally puncture the coil system while drilling
3) the manufacturer did not make a hole, because one was not intended.
Jun 17, 2009 | Heating & Cooling
Sharp AF-S120FX Air Conditioner Logo
383 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
