RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
Posted on Aug 19, 2010
I have a duralast gold jump starter and have lost the adapter that has a nozzle like end that goes into the starter and then a piece that went into the electrical outlet. where can i get another and what is the name of the thing i want?
5 Related Answers
Anonymous
  • Posted on Jan 17, 2009
SOURCE: I have a duralast jump
Adaptor for DURALAST BP-DL
Model HB-208b
Input AC 120V 60Hz
Output DC 12V 450mA
Anonymous
  • 218 Answers
  • Posted on Jan 20, 2010
SOURCE: I have a Duralast Jump Starter BP-ELG and the
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Anonymous
  • 23 Answers
  • Posted on Dec 18, 2010
SOURCE: My Duralast jump starter is dead and when I tried
It will not charge without an adapter suitable for the rated charging amperage. Also,
it must have a ground.
Donald B Stoll
  • 597 Answers
  • Posted on Nov 29, 2009
SOURCE: Where can i get a manual?
They don't have a web downloaded manual.
Phone:
Toll Free (866) 622-7979
(Monday-Friday — 8:30 am - 5:00 pm e.s.t) Mail: RoadPro
1875 Zeager Road
Elizabethtown, PA 17022 E-Mail: [email protected]
Anonymous
  • Posted on Jan 21, 2011
SOURCE: I have a Duralast Gold Jump Starter.I charged the
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Manual de arrancador Duralast 900
English only on Fixya please. We are a North American website.
Duracell Jump-Starter 900 user manual (English - 2 pages)
Manuals.ca
https://www.manuals.ca > batteries > Duracell
User manual. View the manual for the Duracell Jump-Starter 900 here, for free. This manual comes under the category batteries and has been rated by 1 people ...
videos as well
https://www.google.com/search?q=duralast+jump+starter+900+manual
Duralast jump starter says charged but it's not?
You already have a bigger problem. The internal battery won't hold a charge. Time to replace it.
2helpful
4answers
My Duralast Gold Jump Starter does not take a charge when I plug it in to the wall socket. While the charger is connected to it, it will show the green light. But when I remove the charger, after...
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
4helpful
2answers
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
2answers
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
Top RoadPro Air Tools & Compressors Experts
Kardoc
Tami Scott
Tami Scott
Level 1 Expert
goneforever.
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
