Question about Kenwood eXcelon KDC-X689
Kdc x689 battery died faceplate removed. start car stereo will not flip over to reattach faceplate. unhooked battery, turned car off and checked fuses... nothing please help
Did you ever solve this problem? I have the same issue.
Posted on May 29, 2011
Stereo shut down
Did you check fuse block in the car as well as the stereo fuses?
When the face plate is down does that model have any indicator lights in the rest of the deck to see if it is getting power? My old ken wood used to have a red light that blinked behind the faceplate.
Sep 06, 2014 | Kenwood KDC-X993 EXCELON Flip-Face CD/MP3...
Will not turn on without removing faceplate and putting it back in
Try cleaning the contacts behind the face and on the sub panel behind the face with either q-tips and rubbing alcohol or a pencil eraser. If you use a pencil eraser, make sure you brush off the debris.
Jan 22, 2013 | Car Audio & Video
How do I unlock my Kenwood KDC-MP528 car stereo
To reset the code do the following:
1) Turn on the car.2) The faceplate rotates out and the CODE - - - - prompt appears.3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
For further assistance please let me know.
Feb 17, 2012 | Kenwood Car Audio & Video
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
1) Turn on the car.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
I have a kenwood kdc-x689. The screen went dim before it stopped working. The fuse on the back of the unit is still good. Please help me! Thanks!
There are more fuses which are to be checked other than the one at the back , The power supply fuse should be within the fuse box of the car , Do check them and you'll be fixed for sure , Just find the fuse box and how to replace one using your owners manual
thank you
Jun 01, 2011 | Kenwood eXcelon KDC-X689
Display doesn't illuminate on flipdown faceplate
Has unit gotten very cold lately? If faceplate is removable, remove it and clean the brass terminals with a CLEAN pencil eraser, wiking sure to blow off any rubber "crumbs" when finished.
Mar 10, 2009 | Car Audio & Video
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Sep 09, 2007 | Kenwood eXcelon KDC-X689
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Car Audio & Video Logo
164 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
