Question about Linksys WRT160N Wireless Router
How do I change the NAT setting for Xbox live
    President:
  • 1,768 Answers
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
3.
Posted on Aug 19, 2010
  • 5 Answers
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Posted on Jan 30, 2008
SOURCE: Change NAT to open
i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
Posted on Feb 11, 2008
  • 14 Answers
SOURCE: how to fix nat on xbox live
NAT rating can be remedied by either turning on UPnP on your router, DMZ or portforwarding. This site has some good guides on how to improve your NAT rating when connected wirelessly to xbox live:
How to connect wirelessly to xbox live with open NAT
Posted on Jan 11, 2009
kakee
  • 1269 Answers
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Posted on Feb 09, 2009
Joed911
  • 4338 Answers
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
I have xbox live but the nat type is set to strict. How do I change the nat type to open?
All I did was test the xbox live connection then it changed to open again.
Jan 10, 2010 | Microsoft Xbox 360 Console
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
Feb 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
NAt Settings
Are you sure that you are forwarding the correct ports? I also have xbox live, and it seems the closer my router is to my xbox, the better the NAT gets. (wierd) Honstly though, unless you are encountering some extreme lag, I wouldnt worry about it.
Apr 04, 2008 | NetGear WGR614 54Mbps Wireless Router...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
Here you go sir, follow the instructions in the link below and your Xbox live will report an OPEN NAT and it will fix your connection problems.
http://www.portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/Xbox_Live_360.htm
Hope this helps!
Feb 09, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys WRT160N Wireless Router  Logo
466 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
