Question about Nikon D80 Digital Camera
I have a Nikon D80 and one day, I suddenly couldn't take pictures. When I turn my camera on, it automatically blinks the Err message. My shutter mechanics work fine, it recognizes my lenses, and playback is fine, but I can't change any of my setting and it acts like the sensor doesn't work. Is there anything I can do to fix it?
Had same problems. The shutter is faulty although my D80 only registered about 2,000 shots.
Get it fixed at Nikon Service Center. It's your only option. Cost me $120.
Posted on Oct 18, 2010
3 Suggested Answers
  • 421 Answers
SOURCE: nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Posted on Jan 17, 2010
  • 11967 Answers
SOURCE: Nikon D80 Err- No pics!!!
Check Nikon for updates.
Posted on Aug 23, 2009
When I turn on nikon d80 err flashes
The Nikon D-90 users manual says on page 256 that the ERR message indicates a camera malfunction and that it can be cleared by releasing the shutter.
I've found on my D-90 that the only way I can get the shutter to release is my turning the camera off. When I turn it back on the ERR message is gone and the camera functions as it should.
Occasionally, I have had to remove and reinstall the battery to make the camera turn off but this happens only rarely.
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at www.nikon.com to see what they suggest. I think this information would apply to the D-80 as well.
May 04, 2014 | Nikon D80 Digital Camera with 18-135mm...
R05 error on nikon d80
The r05 is not an error message. It is an indication that the camera is shooting in burst mode (multiple shots with one button push) and that you can shoot five more shots before the camera must pause, clean its cache and be prepared to shoot again.
Feb 02, 2014 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Err message
The manual only says when Err starts blinking, press the shutter realise button again. If the error returns, please contact your Nikon service centre.
It is a general malfunction of the camera. There is no such thing as a reset or reboot of the camera.
I think you have tried all the obvious things like switching off the camera, removing the battery an checking if everything is in place and connected. and replace the battery. Did you check the connection points of the battery? Also in the camera. They have to be clean and shiny. don't clean the connection points with a sharp tool. Just a dry cloth or special contact oil. Have you tried a different lens? just to make sure the error is in the body.
Sorry I can't think of more. But I'm afraid you only can contact Nikon.
Nov 14, 2013 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
Nekon d80 erro problem
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jun 01, 2012 | Nikon D80 Digital Camera
Nikon d80 dslr camera working fine and then one day turned it on to take pictures only to find an err message flashing and when the shutter button depressed it says r04. The shutter sounds but no pictures...
HiI am sorry to hear, but you will have to some professional. Regarding your d80 has common problem of sequence unit defective. I believe that is the problem and your local repair shop would charge around $75 to 235 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Nikon D80 Digital Camera
'err' sign on display nikkon D80, and appear r 15 when shutter button is press
"rXX" is just the camera estimate of how many pictures left on memory card. As for "ERR": while camera is in "On" position, take out battery and hold shutter button approximately 30 seconds. Turn camera "off, replace battery and turn "On" again. If thre is a hardware reset button (check manual carefully) while camera is "On" use that reset button/
Feb 19, 2011 | Nikon D80 Digital Camera with 18-135mm...
I have a D80 since 2 years and since last 1 week have been getting the 'Err' message. Initially, after referring to the manual & pressing the shutter release button, the camera responded only ONCE. ...
Hi sandeepbhat2, On page 129 of the D80 manual is the factory reset switch. Look on the left side of the camera there is the terminal cover, inside below the USB connector is a small reset button. Give that a try. If still it does not work you should call Nikon.
Jun 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
Jan 17, 2010 | Nikon D80 Digital Camera
Nikon D80 Digital Camera Logo
713 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
