Question about HP Photosmart C6180 All-In-One InkJet Printer
How can i overprint an 21.5 x 14 centimeters flier with my hp c4400? There is no way to configure the exact paper size and the size is not standard but i need to add an iformation to the flier.
  • HP Master
  • 4,737 Answers
Actually, we set the print size on the document using DTP application like Adobe Pagemaker, Microsoft word, Adobe Illustrator, etc...etc.. but if you've made the changes in the document and want to change the paper size from the printer's settings, you can try this. On the printing preferences, click the drop-down list of the paper size and select "custom", a new dialog box will open up, give a name to your custom size and select the size from the available lists. You can refer to the given pictures below:
and when the "custom" dialog box pops up:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 19, 2010
My Officejet 4500 does not eject a printed page fully, causing the next page to overprint the bottom of the previous page.
Sounds like the printer is set up to print a smaller size paper than the sheet size you are actually using. Measure your paper size, then go into the printer settings and choose the sheet size that matches.
Oct 20, 2014 | HP Officejet 4500 All-in-One Inkjet...
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
The printer will only print one page at a time. even if i select 10 copies, i have to push the green button for the next page to print
This happens because the print job sent to the printer is of different paper size. You need to configure the printer paper size on the printer properties. Always make sure the paper guide is properly set exactly as the paper being fed.
Jul 13, 2011 | HP LaserJet 1320 Printer
Does the used of 1080 have any problems?
The LaserJet 1018 is a pretty simple printer and it doesn't need much in the way of software control. Install the supplied CD and you get a typical HP driver, providing watermarks, – though no overprinting – support for printing up to 16 pages per sheet and the ability to fit a printed document to the size of paper available, great for printing Web pages.
Even its a used model, its really a good printer for personal/Official usage.
Regards
Riztech
Aug 18, 2010 | HP Hewlett Packard LaserJet 1018 Printer
HP 4L when printing an internet page, print size is for
Under print preferences set the paper size to A4.
Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
Aug 25, 2009 | HP LaserJet 4 plus Printer
Hp P4515n - Paper Handling for tray-2 only, gives
I just ran into this same issue with an HP LaserJet P4015n. Worked with HP and the resolution ended up being the following.
Hopefully this will work with the P4515n printer as well.
1. Open EWS page (printer page) in Internet Explorer.
2. Log into printer as administrator
2. Click on Settings tab, Configure device, System Setup
3. You will find Tray Behavior
4. Change tray 2 model to Standard Tray.
This should give you the standard options for the Tray 2 size or default to the size detected.
Aug 20, 2009 | HP P4515n LaserJet Printer
Can't print custom paper size on HP Photosmart C6180
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Jan 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
My printer is printing Ok but the face of the paper is very overprinted and dirty
1- what printer???????????????????
2-what do you mean overprinted????????
I can only think of 2 things, drum cartridge and fuser
Oct 02, 2008 | HP Office Equipment & Supplies
How to print smaller coupons.
I am answering this assuming your printer is attatched to a pc and not a standalone unit. You need to define what size you want your prints to be in the printer settings or properties menu window of your pc itself. Click on your printer icon and go to properties, or it should open up this window when you first go to print a job. Know your required size and specify it to the program you are in, ie i assume because you are printing a flier, you have scanned it first, so once it is scanned, open up the image in windows viewer, and tell it what size you want it to print out. Auto printing buttons on a printer are set to manufacturers default settings to a standard size.
Aug 13, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
