Question about Viking VMOS200 Microwave Oven
Microwave motor stopped working. All else seems OK. Is there a reset someplace in the Microwave?
  • Viking Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 20, 2010
My microwave touch pad does not work except the stop/reset button
You probably need to call the manufacturer. Sorry, no other ideas.
Feb 14, 2013 | Microwave Ovens
Hello, I have a Panasonic MMT573SBBPQ microwave oven. 1. The turntable table stopped working. 2 Tested motor all OK 3. Noticed bulb had blown - replaced this (as was on same circuit as motor) 4. result :...
Check the door switch and once the door is shut the board must be active. If there is no clock or display then the processor board is faulty. Also if there is no action from the touch pad then it must be checked. Since the turntable works as you start the processor seems to work but the output to the magnetron is not active. So you need to check the relay to the magnetron switching, check the temperature cut off unit and the main capacitor.
All the above seems to be suspected.
Attempt with care/caution as there is high voltage present.
Aug 09, 2011 | Panasonic NN-H764 Microwave Oven
Turn table not turning round but heating ok
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
May 18, 2011 | Microwave Ovens
The microwave stops after a few seconds. It starts, but stops before the set time is completed. The oven is five years old.
Does the oven's key pad seem to reset like a breaker flipped inside? And after, you have to reset the clock? If so, check the temperature cutoff switches inside. Jumper across them and see if your microwave starts working correctly. I had this problem and the Bottom TCO was defective.
Feb 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
The microwave stopped heating. Everything else is working fine.
Ok, concerning the heating issue. you will need to replace the Magnetron to restore the heating feature in this unit. this device is damaged.
Concerning the motor(circulation). If the motor is not working, this will damaged the Magnetron, due to poor circulation. i recommend replacing the motor asap.
In conclusion, you will need to replace the Magnetron and the circulation motor as well. replacing these two vital devices will fix your issues. the total cost for these parts are estimated at $87.90
Jun 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Viking VMOS200 Microwave Oven Logo
181 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
