Question about Goodman Heating & Cooling
MY UNIT IS ON BUT I DONT HEAR THE COMPRESSOR KICKING IN.WHAT CAN CAUSE THIS?
    President:
  • 3,773 Answers
Could be the compressor relay and or Thermostat.
Check voltage at wall and at breaker box.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 19, 2010
MY WHIRLPOOL DEHUMIDIFIER MODEL AD50GEUSW IS NOT PRODUCING WATER ANYMORE
This is like a mini refrigerator. Even though you can hear the compressor operating, there may not be enough Freon to cause the moisture to condense.
Sep 05, 2012 | Dehumidifiers
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
Our frigidaire window a/c unit (model faa067p7a) does not seem to be operating properly. There is no condensate forming anywhere (beneath the coils is dry and no evidence of water and there is no water...
It sounds like your unit is low on freon or the compressor is not kicking in. If the compressor kicks in you can hear it turn the unit on fan only or turn the thermostat off then turn the unit to demand cool you should hear a hum even vibration when the unit kicks in. If there is no audible hum ect... your compressor is probably not kicking in. The selector switch the temp switch the capacitor for the compressor or the compressor its self could be bad. good luck if you need to know how to test any of the above let us know
Aug 11, 2010 | Frigidaire Compact Air Conditioner
I have a fedders a/c heating unit that I have been using for about 10 years without a problem. The A/C is now just blowing out air - no coolness. Do I just need to add Frion or can somethign else be wrong?
when you turn on unit can you hear the compressor kick on or is it just fan . I you can hear compressor kick on then most likely you do need a boost of freon but if you can just hear fan without compressor its either freon or compressor is bad or the little secret mechanics dont like to tell??? No joking check the wiring going to compressor pull off the cover where connections are and inside there is a little round surge relay that goes bad often.Its a 10.00 part at any local a/c supply company or you can just bypass that relay but make sure if bypassed that you have the run and start wire on the right peg the wiring diagram will show that if nothing else call a appliance company to come out and total repair bill if it is that relay should be 80.00 hope this helps
Jul 11, 2010 | Fedders A&B Chassis A1A07W2B Air...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
My A/C turns on anff quickly without cold air
look under the car. there is a small wired it sounds like the wired is broken in half...it only takes ten minutes to repair the wired... good luck
Jun 02, 2009 | 2003 Mercury Mountaineer
A/c wont cool despite 2/3 cans refrigerant
A failed compressor can cause this problem, including having a leak that can not be patched with leak stop.
After you turn on the A/C unit, does the compressor "kick in" within a minute of turning the unit on? Do you hear any "clicking" sounds? If yes, post back here and we can take the next step.
May 08, 2009 | Heating & Cooling
Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Apr 11, 2009 | Coleman Mach 15 Air Conditioner
Re: air ride suspension
if your not hearing it kick on then your probley right but i would start checking connections and fuses befor you replace it.
Mar 20, 2009 | 1996 Lincoln Town Car
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
