Question about Dometic Rooftop RV Air Conditioner
Trying to install a roof top AC in my van. Can I run it off of a converter box from a cigarette lighter?
  • Dometic Master
  • 43,501 Answers
No, it will pull way too much power for that...thay pull about 20 amps @120V which would be 200 amps at 12v...get the picture??
Many RV's have a 120v AC generator that they run to power these...
heatman101
Posted on Aug 19, 2010
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I believe...
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
Mar 04, 2015 | Duracell Electronics - Others
Cigrate lighter,radio and foof light does not get on even fuses ar good for toyota corolla 2001
Check these two fuses. Fuse number 31 in fuse box location 4, if cigarette lighter, radio and clock. Else fuse number 5 in fuse box location 2, if only radio and clock and not cigarette lighter.
Feb 06, 2015 | 2001 Toyota Corolla
I have a 2004 Sebring. I plugged in an adapter into cigarette lighter. Car would not start. Jumped the car it is running fine but now my interior lights, power windows and radio will not work. Cigarette...
There's a starter relay in the fuse box under the hood. Have a friend touch the top while you turn the key. If he doesn't feel a slight "tap" then it's most likely blown. Replace. Cheap.
Jan 24, 2015 | 2004 Chrysler Sebring Convertible
Which fuse controls the cigarette lighter and radio, mine are not working
In the integrated power module, find 20A fuse 5. Replacing it should get both the cigar lighter and radio operating again
Oct 12, 2012 | 2005 Chrysler Town & Country
My cigarette lighter and my radio stop working suddenly when I pull my 120v converter (that fell to pieces) out of my lighter, what happened?
These two devices both use the same fuse. Look under the steering wheel to the left and you'll find a fuse box. Pop the top off of the box and look at it. It has a diagram on it to tell you which one runs the radio/lighter. It's a 20Amp fuse. Pull it out and examine it, it should be burned/broken in the middle, you can see it through the clear yellow plastic. Replace the fuse and your devices should work again.
Jun 16, 2011 | 1998 Suzuki Esteem
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Where is the fuse for the cigarette lighter for a 1995 rocky ridge high top conversion van. the van is a 20. I've also notice that the over head lights don't work either. looks like they are both wired...
THERE MAY BE A FUSEABLE LINK ATTACHED TO THE REAR OF THE LIGHTER ITSELF(OLD SCHOOL INLINE BUS FUSE) PULL THE TRY AND CHECK THE FIRST 10" OF RED WIRE RUNNING OFF LIGHTER
Sep 12, 2010 | Chevrolet V20 Cars & Trucks
Ford Escort Van
The I/P fuse box has six fuses off by themselves.One side has an open slot. The other has two fuses side by side. The 20 amp fuse closest to the box center ,of this pair, is the cigarette fuse.
Jul 09, 2008 | 1998 Ford Escort
Digital clock and cigarette lighter
There are three (3) fuses involved here. The one that is most likely the culprit is the 15A one in the fuse box under the hood, near the battery. Check the underhood fuse box, replace any blown fuses.
The other two fuses (also 15A) are in the interior fuse box, probably left side kick panel.
Jul 02, 2008 | 1987 Toyota Camry
Dometic Rooftop RV Air Conditioner Logo
1,157 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
