Question about HP LaserJet P3005 Printer
Getting black streakings across page. New Cartridge. Test page come out clean and all the rest black
  • HP Master
  • 1,121 Answers
Replace teflon sleeve....
Posted on Feb 03, 2012
DJYar
  • 41 Answers
SOURCE: black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Posted on Aug 23, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Posted on Oct 26, 2007
jaylex
  • 417 Answers
SOURCE: Ricoh Aficio cl2000
The following is taken from the service manual I hope it helps thanks J
4.3.1 BLANK PRINT
Symptom Possible cause Necessary actions
Defective laser scanning unit Replace the laser scanning
unit.
Defective PCU Replace the PCU.
Defective transfer belt unit Replace the transfer belt
unit.
tension unit
tension unit.
Defective toner cartridge
drive unit
Replace the toner cartridge
drive unit.
agitator
Replace the toner cartridge.
Incorrect action of transfer
roller
Check the guide and the
transfer roller.
Defective high voltage
supply board
Replace the high voltage
supply board.
No image is printed.
Defective engine control
board
Replace the engine control
board
4.3.7 WHITE HORIZONTAL LINES OR BANDS
unit.
White lines or bands appear
in images of all toner colors.
They are vertical to the
paper feed direction. Defective transfer roller Replace the transfer roller.
4.3.8 MISSING PARTS OF IMAGES
unit.
Some parts of images are
missing.
Defective fusing unit Replace the fusing unit.
4.3.11 DARK IRREGULAR STREAKS ON PRINTS
Unexpected streaks appear
at irregular intervals.
Defective transfer belt Replace the transfer belt
unit.
4.3.17 NO PRINTING ON PAPER EDGE
Defective toner cartridge Replace the toner cartridge.
unit.
images are not printed in the
areas around the paper
edges.
Transfer belt not contacting
PCU
Check the belt tension unit.
Try these hope I could help Thanks J
Posted on Jan 13, 2008
  • 47 Answers
SOURCE: HP laserjet 3030 black streaks
You have useful help if you measure the distance between the defects. If the lines are repetive, use this link http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00063561
Posted on Nov 05, 2008
yooperbud
  • 8637 Answers
SOURCE: Streaks on photo sensitive drum HP laserjet 5MP
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Black page streaks
Hi
first check toner cartridge, if you have another test and if the problem is continuing fuser unit and will have to clean or replace it with another.
Feb 03, 2014 | Canon imageCLASS D1150 All-In-One Laser...
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer is running a white streak through the center of pages
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
Black streaking across the page in 7 sections
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Oct 30, 2008 | HP LaserJet 1320n Printer
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Black streaks on printout page
Aug 22, 2007 | Brother HL 1440 Laser Printer
HP LaserJet P3005 Printer Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
