Question about Harman Kardon AVR 310 Receiver
Seems to show working order,BUT! THE problem is there is no volume coming out. i plug the wires to out-put from tv and then into input of AV310,but even when changing the outputs to spk channels/cd/tape/ or others,there is NO output of volume. The unit shows all front to be in working order,as far as changing the different settings, BUT no noise comes out. I tried all inputs and output settings and nothing/no volume goes through it. Is there a fuse inside that might have been blown out? There also are setting little light on front of screen, to left and right, that are not light up. I thought those might be to see when using the remote. I have ordered the remote, but not here yet. I bought this used form thrift/Salvation Army store and so I do not know it to work from there. I was hoping there was no problem with it and yet now that i have plugged it all up and checked the speakers,settings,inputs/outputs i seem to see that it does not work, with at least the power/volume to speakers,at least.
  • 1 more comment
  • Michael Thompson
    Michael Thompson Aug 19, 2010
    I will try this for sound.
    I did open the unit and found that the 2 fuses of 4 where blown.
    they are 2amp, 125/250 type fuses. I went to Radio SHack and bought a 4 pack of them
    They where placed in the board and then i covered it and proceeded to wire the 2 speakers from out-put of center and the right speaker out terminals.
    I then put the wire to tv(52inch flat screen LG) where it said output audio and ran it to the in-put terminal in back of av unit.
    I plugged it in and it turned on and little,"POP" noise and the 2 fuses went out .
    For a second the lights came on,in front display, to right and left, where little light dots indicate control adjustments would be made and seen.
    I did not see those at first, of course from the 2 fuses being out in the first place.
    I am thinking there is some problem, beyond the noise not coming through, because of the blowing of the fuse issue.
    Is there something that the fuses,: IE: NOTED AS: fu-483 and fu-484 slots, where fuses: A:SB2/125v-D:t2a/250v , would be placed.
    I am guessing there is something that is causing the fuses to blow? that would inhibit the noise/volume to be given through the unit?
    If i use a slow burn 2a- 250v fuse, that should not be a problem, right?
    I was hoping that the fuses NEW replaced would be the cure and yet it seems to be something else.
    I wrote you all and then opened the unit, so i found the fuse issue and yet if these keep blowing then there is another issue at hand,before the volume can be addressed.
    I would think if the fuse issue is fixed then maybe there will be no wire/volume/noise issue at all.
    Please let me know from here,what you can sugest.
    THANKS soooo much.
  • Michael Thompson
    Michael Thompson Aug 20, 2010
    Yes, I see,(said the blind man/me) so i read this sort of thing in the other blogs/sites.
    It is not speaker related,it is blowing fuses in slots fu-484 and fu-483, for sure relating to what you have pointed out.
    I am using TV 52 inch flat/1 yr old- Samsung ,and i have used other 7.1 channel unit,which worked fine. JUst buying this HK for looks, more than anything else.
    I figured that others may have been up against this sort of problem and so it could be passed to be the parts to fix,or idea of what i might be able to fix. If a person would know and or have had the same issue,then it could be told to me, to just fix this or that. I can replace about anything, in general. I am not good with tech checking things, but if i see obvious fuse and or a person can direct me to replace something, then i can do all of that. I am very mechanical but it is not so when i am to see if something with wires and transistors are to be checked.
    THis is where i hoped a person could said," that is the issue,i have seen that before", then to direct me to the fix. Of course without a direct part to fix, i would need to tinker and read, buy manuels and tinker more, but of course my time is better spent to drive it to a shop.
    If it was a high 800-2000 spent on this, i might be inclined to fix it and to the work on reading and going mechanic/tech/fix-up/wiring person on it, BUT i figure i got $6 in on this, then $10-15 on a Manuel, then? parts and of course the $50 i bought it for,so then it might have been better to just by a working same unit from ebay or somewhere for $50 more.
    I do appresiate the help and time you all have spent on directing me to the issues and thoughts of fixing it. I will look over the notes here a little more, BUT, if i can not see a ovious issue,(like the 3 prong thing,in the diogram you show above) then i will probably let a shop get after it,,within a resonable price to fix it.
    I can see no more than 200 in this, being a saw one go for $212 on the bay. I would figure they paid ship as well, BUT i am cutting this off at 2 bills and calling it a loss of $50buy-$6 for this help, and $4 with the 4 fuses i bought already. I am at $60 on this already and so i will go $100-140 more if a shop can fix and a guarentte of at least a YR for what i spend to get it fixed.
    I still hope to hear from a person that can direct me to what the problem is, BEING i am sure there are others with this same issue,with this same unit :HK AV310.
    I would guess the person/owner that bought it? or next person, used it to loud and blew the amp parts,which conect to these 2- 250v fuses that keep blowing.
    I would bet a person at or from HK has seen this and know what parts need to be changedfixed.
    When the fuses where replaced, the left and right lights came on, so i would figure that with these two fuses known and the lights details and the ovious of the volume/noise, NO Sound going through, these details are a major hint of the exact problem.
    I do not know much, but i would guess 95% sure it is a issue of power to the amp/vollume/power through these issues.
    Thanks for all the help and PLEASE if there is a person that knows and or have heard of this model and such of this issue, then let me know any details. I would like to just clip and resoder the parts, for sure. I read,( from goolgeing this exact issue: HK AV310 BLOWN FUSES) that there are others with same issue, BUT i do not read that they have fixed it and or 1 person said buy the manuel, which is good for the techy person that is ready with a solder iron at hand.
    I have a solder iron, but it sees very little use, 1 time every yr or so.
    I can replace ANYTHING at all, or can attempt it, no problem at all,( i have been doing Marble/GC work for 30yrs) but the time spent on manuels and checking/testing is not my thing.
    My wifes father was a Rocket Scientist and would have fixed it,no problem, BUT he passed on a few yrs back, from an odd problem, rare issue at would make him just black out, like no power at all, then black out, and no cure at all. It took him out in 8 months, like getting MS and in a very sort time he was gone.
    He had ALL the electrical tools and knew how to build tubes ,(from the past) and all into GPS, where as he first companys built the first GPS systems, then he went into Ford AeroSpace, over next to SF,Ca area.
    I am hoping a person can gleem enough from this info to have run across a person that can say, (within 80-90 percent sure) to just replace a part related and or a pretty certain to be the cause part i can replace. I am pretty sure a person just cranked it up to much and blew out the normal part that conects to these 2 fuses.
    The rest of the unit lights up, the front screen, the little red details in center right and all the front details show to work, when dialing, or puching the buttons. It is the far left and right detail, (WHITE LIGHTS/ITEMS) that do not work, but did when putting the new fuses in.
    Maybe there is something else i can see and with the explain i see above in responce details, i will look at that, of the 3 prong details to check.
    It is nothing about the speakers i am using and nor the TV unit, all those are in Mint and or new condidtion and have worked with other units/items. It is certainly to do with POwer TO AMP fuses.
    2 burn out and yet the other 2 are not effected at all.
    I would hope not to buy a manuel and or spend time to fix/replace parts that lead me knowwhere other than more loss of time and funds.
    I think the information i have gathered is in the right direction and maybe somebody can get me to the best place,to where there is a normal/average problem part that is shown to be the normal problem connected to these 2 fuses in question.
    If it has happened to this unit, then i am sure it has happened to many more at this point, from this unti being 2000yr unit and seeing many more people of writing about issue on this unit.
    Again, i am guessing it is a part i can replace, that is a AMP/VOlume, front lights,(left-right/white lights)related, 2 fuse - fu-484 - fu-483 , related problem parts issue.
    I also then have to wonder, can i get the part/parts? so i would not want to waist my time there as well, BUT if there is anything, just anything, with all this information a person can help me with, it would be a GREAT HELP.
    I am sure the ROcket Scientists have brought down from space, problem ships, with less information. That is what my wifes father did, trouble shooting issues was his thing. Speaking with the Astronauts to fix things so to get them Sq. with helping them susceed and find there way back down save.
    I called him,(nick name) Macgiver Bill. His nick name was Bill H20, and as well with Ham Radio club he was into.
    PLease let me know,if anybody can make sense of this LONG Notes and slight Soap Box writing and such details.
    Thanks so much, DUNKA, GRAZIE, And best regards 2 U all !!
  • Michael Thompson
    Michael Thompson Aug 23, 2010
    Right:
    As so far as the Manuel,that i do not have.
    It is blowing the fuses in fu-484 and fu-483 sots , 2 of 4 slots where 250/125v are inserts.
    When pluging it in the fuses blow and so there is nothing i am inserting, as so far as wires to speakers and or the tv output.
    I would say there is something that is causing the fuses to blow,that then will not let the unit work.
    I am guessing that there is only for a person to buy a Manual and or have a electronic person go through the checks to ascertain the reasons that might be causing these fuses and unit not to work.
    I do not have the time to check this and that, then as well buying a manual and the unit, then the remote and tossing this service that is not, pointing out the item to which i can change, so i would not want to spend more time and funds on a 10yr old unit.
    I can drop $100 more into a person to fix it and the parts, then after that i would be in the hole from where another person just bought a working unit off ebay.
    If a person can find or know of this problem,(with ALL the information provided,fuses 2 and which slots and the unit type and in general what might be the problem from hearing or reading this issue for same unit where in the last 10 yrs) then i would greatly be happy to change the part.
    I might by the manual ,but i would not see using it to tinker and hope to fix it,being it might be a to long process and i have on time to do that.
    Maybe there is a person that has better knowledge of this sort of issue and knows this model, where it is known,this issue and what these 2 fu-484 and fu-483 fuses are relating to, so i can replace the problem parts?
  • 3,247 Answers
It appears you do not have a user manual for this receiver. You can get it from this site.
You will see on page 52 there is mention that if no sound from speaker. It is possible the speaker wiring is shorted either on the connector or a speaker is faulty. The amplifier protects itself. Also check you have selected the correct speaker settings.
Hope this helps and you enjoy the system.
Posted on Aug 20, 2010
  • 5,807 Answers
To work with the unit ( while waiting for you remote )
you may need to check on the manual first.
[PDF] AVR310 Product Sheet - Harman Kardon( click on the link above for more details ).
you need a PDF reader to read the documents after
downloading and saving it on your computer
• If the operators manual still wont do , you may need to
check circuits inside the unit having a troubleshooting
guide like one from here:
a ) Start with the input , then to the op-amp IC. b ) check your cable like those above for co
( click on the link above , just for sample troubleshooting ).
And may need a signal injector or a signal tracer to
properly find the cause.
• A signal tracer can be a simple audio amplifier just to
test if the signal is passing through the stages of the
receiver.
• If you found that signal have been cut-off on some stages
then it could possibly be from the supply ( low voltage )
or the IC on the Circuit.
Here is a simple sample Signal Tracer:
• But start on the speakers first , you can use a Remote
1.5V battery or 2 and connect it on your speaker
( temporary tester ) , if you can hear scratches on your
speaker then your speakers are probably good.
( actual performance will be heard if the amplifiers are
already working. )
Inside the unit , the Main Amplifiers ( one driving your speaker)
needs a good power supplies rails.
• These amplifiers needs a preamplifier to match the input
impedance of the " Source " input and to tailor the sound
according to your needs.
So Divide and Conquer to find the cause.
It may take a while , but it needs a lot of patience to work
on electronic circuits.
And if you need to have the service manual
http://911manuals.com/product_info.php/products_id/217866
only with a fee.
• Check for " Preamp " power supplies and low voltage
regulator or possibly just a cold solder joint on it.
( If main amps are OK )
  • 7 more comments
  • Rommel Cana
    Rommel Cana Aug 20, 2010
    I forgot to ask the Model of your TV , so I can help you further
  • Rommel Cana
    If the fuse are blowing one of the many possibilities are a shorted Power
    Transistors
    in these
    area: ( at the back of it )
    I will post the part number should you choose to DIY
  • Rommel Cana
    and it may looks like these :
    • Insure that there is no shorted pins 2 and 3 on all of the same kind
    ( mounted on the Aluminum heatsink )
    • If you have found even one , disconnect the pair of that power transistor.
    it is always a PNP and a NPN ( check on the link above )
    • Then power it up once again , your amp should work without that missing pair
    of power transistors.
    Then you have the option to buy that pair later, But you can use the unit , only
    that channel or part will not .
    If these is not the case , post what you found and will give you more details how to
    solve your problem.
  • Rommel Cana
    As I am reading your additional comment :
    • If your fuses blows it means a bad components along with it
    one possibility is the capacitor C487 ( 6800 uF 16 V ) [ most common ]
    have it replace or check the diodes before it
    • diodes D568, D569, D 570 and D571
    or
    • the capacitor C 488 ( 2200 uf 16V )
    or
    • might also be from a bad regulators IC 483 and IC 486
    • There is a service bulletin that states that do not replace the C487 with the original part number
    but have the updated part number on it.
  • Rommel Cana
    • here is the location of C487
  • Rommel Cana
    • and here it is in schematics:
  • Rommel Cana
    Rommel Cana Aug 26, 2010
    since you have a soldering iron, might as well unsolder or remove one terminal of
    each of the diodes indicated. and post back.
    you do not have to buy yet.
  • Rommel Cana
    • positive side of diode D568 1N5402
    • positive side of diode D569 1N5402
    • negative side of diode D570 1N5402
    • negative side of diode D571 1N5402
  • Rommel Cana
    Rommel Cana Aug 27, 2010
    • lift one part ( pin of the diode ) and check
    Testing Diode-How to test semiconductor diode using multimeter
    How to Test a Diode | eHow.com
    these two links should help you test the 4 diodes.
    Brigadier General:
  • 3,513 Answers
Hi
Connect the optical audio OUT on the TV to the optical audio IN on the receiver. Turn the receiver on and set it to input as it was labeled on the connection ("video" or "auxillary" or such). Turn the TV on and set it to an active TV channel (with video and presumably audio info), not to VIDEO 1.
Alse Check the mute is on or not,or you have connected to wrog input or wrong speaker is selected or not.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
I have a samsung tv and for some reason the volume control is always on the screen even though i am not using the volume and it prevents the remote from working other then that everything seems fine. I...
did you try without the remote ?
remove the battery from remote and check.
did you try with another remote ?
did you try with other input sources ?
did you try factory reset of tv
Dec 18, 2014 | Samsung Televison & Video
Plasma screen is blue it has been taken off wall think something may have been touched/flicked
Blue screen means no input. First make sure the HMDI cable and the device you get your golf results from is properly sending the signal. After that, you can then make sure that the TV screen itself works right by using the remote to change volume and ensure that it the screen shows the volume up graphic display. Once you know that is in working order, make sure you are on the right input channel by looking at where you input is plugged in to and setting the TV to that input via the remote. You can repeatedly hit the input button to cycle through the inputs if you want to be sure. (there are 8 of them) The last thing you can try is assume that the input you are using is bad and switch to another. (Go from HMDI 1 to HMDI 3)
Jun 14, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Seems like some type of control board problem. Remote will not work on tv, but works other devices. Manual controls are squirelly. Cannot change inputs. Can move to other inputs on menu but when I hit...
Thats a bad button on the front keypad of the tv . The remote does not work because the tv micro sees a button pressed all the time and never listens to the IR reciever . If you pull the front speaker grill off you will find connector ZF just below the keypad or just inside the access panel. If you do remove that panel don't touch anything else.Just follow the wires down from the keypad to connector ZF. Connector ZF is inline with the wires to the front keypad. Unplug it . Then remote will work like normal. Use it like that or have the front keypad buttons replaced.
Oct 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My older Yamaha receiver has lost volume on the TV output.
if TV outputs are okay.Then simply connect TV into another input on reciver, AUX,TAPE,VIDEO ETC...if problem persist then output from tv is the problem..check settings on tv
Jul 29, 2009 | Yamaha RX-V2400 Receiver
TV wont read any of my game consoles input signal
i had tht EXACT same tv in white and i used to play game systems on it. eventually i got bad joo joo and it stopped working :/
May 15, 2008 | Toshiba 36A50 36" TV
Mintek Fix
Mike
The biggest reason is the input on your TV will be stuck in DVD mode. Therefore the set expects any audio to becoming from the DVD player and not inputs on the back of the set. So every input on the back of the TV except for the component input is non functioning. Another reason is that you have no way to control the volume of the TV since there are no functioning buttons save the power button.
If you cut the speaker wire in the TV and solder to the respective RCA connections on the back or side of the TV you can treat the speakers passively, meaning there must be some sort of amplifier to power them. You could also just splice some wire to the cut speaker wire to extend the speaker connection to an amplifier, but I'm not a fan of loose wires coming from the back of my TV.
Therefore, using this set up you would have your cable box attached to your TV and an amplifier of some sort, and the amplifier attached to the RCA connections you soldered for the speakers.
Here's an amplifier that would work for fifty bucks:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-958
To turn the TV on just make sure the power button is pressed (this will put the TV in standby) and then press any other button on the side of the TV: Source, volume, any of them will work.
In order for your cable box's remote to work it will need to be programmed for the TV. I have been unable to find the program codes for the TV, but I do know that Comcast's cable remote will work if you do the code search. You do need to reconnect all the grounds that you disconnected as well.
Let me know if you run into anything else
Ryan
Mar 11, 2008 | Mintek DTV-263 26 in. LCD Television
Harman Kardon AVR 310 Receiver Logo
342 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
