Question about Microwave Ovens
Start Stop Push Button broken, where do I get replacement part and what is the part number?
This part is available from Sears for about $8.00
Posted on Jun 27, 2008
    Scholar:
  • 58 Answers
Calling manufacture is usually the best bet to find part numbers and distributors in your area
get the model and id go to marcone.com, repairclinic.com, and partselect.com are the most common for me.
most the time its called an ECB(electronic control board), PCB(power control board), most the time if its called a control panel they are refering to the decorative part cover, so look at the list carefully
Posted on May 02, 2008
MY 27 INCH VIKING PROFESSIONAL BUILT IN MICROWAVE OVEN ALLOWS ME TO SET THE TIME, BUT JUST COUNTS DOWN SILENTLY INSTEAD OF MICROWAVING WHEN PUSH START. CAN THIS BE REPAIRED? OR IS THERE A RESET?
Your bottom door switch is probably defective, or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
See my help files on safety here, disassembly here, and door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Viking Microwave Ovens
If left plugged in, microwave fills timer screen with "7's" then scrolls "push start". Circuit board? Fix?
I would say that the number 7 button is either broken or stuck in. If still under warranty, take it back. Otherwise, contact the vendor of the microwave and ask them how much it would cost to fix it. Generally, it's cheaper to buy a new microwave than replace the circuit board, unless you can find second hand parts on eBay or a similar site.
Jul 14, 2015 | Microwave Ovens
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Whirlpool microwave start button not working
There are 2 possibilities the first is that the button is locked. Some modern microwaves have lock buttons so children do not play with them. To unlock it you can try either holding th "start" button until you hear a tone of hold the "stop/end" button until you hear a tone. If that does not work it means that the button it self underneath of the plastic is broken or blown which means that it must either be repaired or the microwave must be replaced. For the price it may be more cost effective to replace it is the button is broken.
Sep 26, 2012 | Whirlpool RMC305PD Microwave Oven
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
Door won't open. push button doesn't work
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 06, 2009 | GE Microwave Ovens
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
