Question about Raypak Pool & Spa
Raypak versa 130 above ground natural gas heater 40 days old leaking from the bottom
    Top Expert:
  • Raypak Master
  • 4,206 Answers
Bad pool chemistry heat exchange leaking replace warranty will not cover
Posted on May 25, 2016
  • 22 Answers
SOURCE: Raypak FFL Fault Code
the ffl is a false flame sensing when the heater is not in call for heat mode.
Posted on Feb 21, 2009
  • 139 Answers
SOURCE: I HAVE A RAYPAK VERSA, PILOT IS ON , BURNERS DONT COME ON
check mv output of thermopile ,unless you have 350-500mv it is not enoughvoltage to power valve
Posted on Jun 20, 2009
johnsonr1
  • 91 Answers
SOURCE: I have a versa gas heater for my above ground
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Posted on Aug 22, 2009
  • 990 Answers
SOURCE: pool heater works intermittently. have replaced thermostat kit
Depending on model you will need to ck ethier millavoltes (1/2 to 3/4 of a volt)or 24 volts. but this sounds like a pressure problem. Start by cleaning your basketsand your filter. If this dosn't help you should pull the presure switch from the manifold on the heater and see if their is any corrosen or rust on the sw or in the manifold. One of these should fix your problem. Good luck.
Posted on Nov 27, 2009
Testimonial: "thanks!"
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
Rapak above ground pool heater is leaking from the bottom
leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
Aug 20, 2010 | Raypak Versa 130,000 Btu Above Ground...
My Versa Raypak heater will not light and I am not mechanical minded enough to make repairs. Is their a Raypak authorized repair service in Lancaster, CA?
A V HAWAIIAN POOLS INC
4085 WEST AVENUE L
LANCASTER, CA 93534
(661) 943-0557
redletter-b.png 31 miles
Directions DENNIS RETTELA'S SWIMMING
11463 ORCAS AVENUE
LAKEVIEW TERRACE, CA 91342
(818) 896-4690
redletter-c.png 44 miles
Directions VALLEY HOT WATER
4212 E LOS ANGELES AVE
SIMI VALLEY, CA 93063
(805) 526-5594
Aug 04, 2010 | Raypak Versa 130,000 Btu Above Ground...
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
Pool & Spa Logo
65 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
