Question about HP Officejet 5610v All-In-One InkJet Printer
I have an HP 5610v All-inOne printer scanner fax, it has always been connected thru my USB port has worked great, all of a sudden my print que says I have a paper jam - I cannot find it what so ever, I can manually print a self test report using the buttons on the printer, but sending a print job to the printer forget it, please help?
Not insttalin hp5610 all inone
Posted on Mar 08, 2011
    Problem Solver:
  • 10 Answers
My Lexmark X5400 series printer tended to do this, the following troubleshooting is what has always fixed it for me. Starting with simplest to most extreme fixes..
1. Reboot PC, with PC down, Unplug Printer for at Least 30sec, Restart Printer Then PC. ("Note you must unplug printer, don't just power it off")
2. Try above steps but also disconnect USB cable. After PC starts and you are logged into windows, Click Start>Devices and Printers (Win 7/Vista) or Printers & Faxes (Win XP), and look for your printer to say "Unavailable/Disconnected" in the "Status" for the device. While the printer is turned ON, reconnect the USB cable and wait on Windows to re-detect the hardware.
3. If above steps fail,
A: Use Add/Remove Programs or Programs & Features to completely remove all software installed for the printer, BEFORE shutting down
B: Right-Click your My Computer Icon (Either on desktop or start menu in any Win OS), go to Manage in the pop-up context menu, Then on Left-Hand side, go into "Device Manager", Under "Universal Serial Bus Controllers" expand all the tree's listed until you see your Printer,When found, Right-Click and "Remove" your HP printer if listed, clicking "Yes" to the pop-up. ("NOTE: After software uninstall OR if the printer is unplugged OR USB disconnected, you may not see your device listed here at all, if not, that is fine, skip this step")
C: Disconnect the printer from the PC, reboot Both devices, then proceed with manufacturer's instructions as if you had just purchased the printer for re-installation.
(* Anytime "Reboot" is listed for a printer, this generally means to unplug it, as powering off only puts several models into a "Standby" state, which doesn't reload the firmware and perform system diagnostics on power on if device was previously powered on*)
Posted on Aug 19, 2010
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
Will not print on command
Greetings welcome to Fixya.
Might I suggest downloading and installing the latest drivers for your HP Printer.
See my published guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
Be sure to connect the USB cable to both the computer and the Printer then turn on the Power. Try different USB ports on your computer/laptop.
Navigate to the Windows control panel and double click printers and faxes.
Click print test page on the bottom right of the box.
Also view the print que, right click on your printer and set it as the default printer.
Then in properties view the print que!
Also when you are printing in MS Word, click file print, then when the settings come up for the print ensure that your HP PSC 2410 All-In-One InkJet Printer is selected in the top most section of the box.
Tell me how it goes via comment!
Thanking you
damnor01
Mar 11, 2011 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
Printer has always worked great, gets lots of office usage, but now suddenly won't feed; the machine will turn on, when the print queue is activated, but just "clicks", won't feed and the error...
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP LaserJet 1020 Printer
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart printer --lost the CD
check if they r are any documents r pending in the print que, u can try to cancell all the print job. also u can check the printer port, if the ip add is correct, & if u need the driver u can log in to hp.com & get the driver
Mar 31, 2010 | HP Photosmart Wireless Multifunction /...
My hp photosmart c4480 will not print attached to my laptop it keep putting the print jobs in que
start - print and fax - right click on HP Photosmart C4480 - properties - port (change to USB)..
Feb 21, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Hp6310 won't print wirelessly with apple airport
the air port is faulty.the port will be loose internally connect it properly.
its a common cause in airports.
Apr 01, 2009 | HP OfficeJet 6310 All-in-One Printer...
Cant fax
Are you sure the FAX line is connected to a working phone jack and plugged into the correct jack (line not phone) on the machine?
Step by step FAX instructions can be found here on the HP website.
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610v All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
