Question about RCA RTD3133 Theater System
I have hooked up the audio to my tv from the audio out and connected it to the dvd player audio in and cannot get sound out through the external speakers. I have connected all the speakers correctly. Please advise. Thanks.
    President:
  • RCA Master
  • 1,779 Answers
It goes Audio Out of DVD to Audio IN of TV or Amp. The audio out of a TV must go into an amplifier, not just a player. A player does not have an amp built in. Not the add on type that you have.
Posted on Aug 19, 2010
500 watt tower spkrs unable to hook up to tvhoo
If the speakers are powered with their own amplifier, then connecting them to the audio out terminals on the TV will work. If the speakers have no amplifier, then they will never work on your TV. You must go to the audio setup on the TV to redirect the sound to the external jacks.
Dec 12, 2016 | Televison & Video
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Playing movies from external hard drive
Hi rox09
Well you can rip your DVD to any external drive using and third party DVD ripping software ,once you do that you will get a AVI,MPEG and any common fomats your DVD player supports
Inorder to play those files in your DVD player ,you need the check whether your DVD has a USB input port or else if you laptop or computer has a S-video out put and your TV has S-Video input ;you can play directly from your laptop/computer to the TV using a S-video Cable which is available in any Computer shop.
I hope this helps
VJ
Mar 15, 2009 | ASUS Eee PC 900 Notebook
Sound through tv on M280 portabel dvd player
Do you have both video and audio cables connected? Yellow or S-Video cables are only for video, you also need to connect the red and white RCA connectors on player and TV for stereo sound.
If you have already done this, check the player's menu to see if there is a setting for external or auxiliary audio.
Jan 26, 2008 | Amphion Mediaworks M-280 Portable DVD...
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
RCA RTD3133 Theater System Logo
161 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
