Question about Hifonics BX1500D Car Audio Amplifier
I got a hifonics brutus 2000 watt it says its a 1ohm stable amp but don't know? I got 2 empires 12" they say 4+4 ohm 4000 watt a piece I got both of them wired to 1 ohm n. I'm usin 8 gage power wire on the amp n capasitor , d main power cable wich is d + has no fuse, evrything turns on good. But wen I turn it up loud it bang hard n then ill go into protec mode. N ill stay there n ill only power back up if I turn d car off n then bak on , so I tried wirein d speakers bak to 4 ohm but they don't even bang! So I stoped messin w it , so then I wake up n try to turn on d car n d battery is dead! I took it o auto zone they charge it n they said it was good! I still got everythng hooked up but I turned d base real low n it won't go into protek mode no more n this amp supposed to b a beast ! I'm new at this . 2 autosound. Places told me I need 4 or 0 cage power cables n a drycell battery? Wat y'all thnk? Please help!!
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
  • 102 Answers
SOURCE: hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Posted on Mar 09, 2009
rteemon
  • 578 Answers
SOURCE: second opinion on wiring
run seperate
Posted on Jun 26, 2009
  • 13 Answers
SOURCE: hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
Posted on Aug 08, 2009
Professor_V
  • 92 Answers
SOURCE: where can i get repair parts for a hifonics brutus
THE NUMBER FOR MAXXONICS IS 847-540-7700, BUT I BELIEVE YOU WILL FIND THAT THERE IS NO PARTS DEPT. THERE. IF YOU CAN READ THE NUMBERS ON THE DEVICES IN QUESTION, I MAY HAVE THEM IN STOCK. I AM LISTED IN THE REPAIR DIRECTORY OF THIS SITE AND CAN BE REACHED AT PROFSRVCS@AOL.COM LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Posted on Jan 06, 2010
Wire 3 12 " p2 2 ohm to 1001 watts hifonics brutus
best i can tell, the amp is stable @ 1 ohm, but 6 colis x 2o ohms is 12 ohms, and 2 ohms divided by 6 drivers is 1/3 of an ohm. you will have to study ohmms law, and parallel versus serial wiring resistance results to get as close to 1 ohm, without going under it. i honestly thing that 1.66 ohm is the closest you will get
Jul 17, 2014 | Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
I have 2 kicker cvr 15 4ohm dvcs and a performance teknique ICBM power 4000 watt 1ohm stable amp when I hook up my speakers 1 ohm it kicks my amp into protect when I wire it at 4 ohms it works fine how do...
Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
Apr 11, 2011 | Performance Teknique Car Audio & Video
I have 2 12 inch jl audio w7's with a kicker crossover and a powerbass equalizer 5 bands. i wanted to know if add a hifonics brutus 2100 d class amp to my subs at 1 ohm would it over power my subs. please...
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Dec 22, 2010 | Hifonics Car Audio & Video
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
Hifonics brutus 2000 watt help??!!??
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Jan 29, 2009 | Hifonics Brutus BXi 606 Car Audio...
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hifonics BX1500D Car Audio Amplifier Logo
153 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
