Question about Zanussi ZWD1470W Front Load Washer / Dryer
My drum on my ZWD14270W has stuck solid half way through a wash. i have checked the belt and that was off but the drum would not budge manually its like the bearings have seized up but there is no leakage of grease from the bearing cage and the bearings look fine to me but i could be wrong. can anyone help me?
  • 269 Answers
It could be either the bearings have collapsed and seized or that an object such as a sock,stone,screw or the like has got down into the drum and jammed it solid.one way to see if it is a small object like a stone or screw which may work is to undo the screw on the pulley,this is normally a torx screw,you will have to undo in an anti-clockwise direction,then gently prise off the pulley but be careful its soft alloy and could break,once off try jiggling the drum it has some end play and this may be enough to release the jammed article.If this does not do it then the drum will have to come apart if it is a split type drum unit.Also try looking around the front by the door seal sometimes if a sock gets stuck it can get jammed around this point and you may see a piece if so then try pulling out with a vice grips,normally takes a hell of a lot of sheer force to pull it out.
Hope this helps.
Posted on Aug 19, 2010
My Hoover vhd 8142 washer wont turn. Some clothes got stuck in the doorway and when it spun it twisted everything up and pulled the seal off the door. We managed to get the seal back on. We put a load in...
Sounds Like the friction on the belt.If the drum got stuck the motor & belt keep turning plus the drum may of been pulled to an off set angle distorting the alinement's of the belt to the wheel that turns the drum.
Oct 01, 2017 | Hoover Washing Machines
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
1992 626 Rear Drum stuck
Does it have a dust cap in the center? If so, pry it off and remove the nut. It also might have a reverse thread (check). If it doesn't have the cap, then you might have to cut the drum in half. But I am almost positive that it does have the metal dust cap in the center of the hub/drum. I sincerely hope that this helped you. Let me know how things went. I'll still be here if you need me.
Bryon
Mar 20, 2009 | 1989 Mazda 626
Machine won' spin
It sounds as though the main drum bearings have failed.
If you turn the drum by hand and it feels rough or you can feel it grating or rumbling, then the main bearings have gone.
Quite a major and expensive job to put right, you may find it more econonomical to purchase a new one.
Plz rate my comments.
thanks and a merry xmas.
Dec 21, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Drum stuck fast
hiya
sounds like the drum bearings may have seized, or they are worn and the belt has come off and wrapped around the drum pulley. a few things you can check are:-
does the inner drum have any up and down movement to it?
does the belt appear to be on ok? (you will need to remove the lid to see)
have you noticed any black marks on the clothes recently?
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Jul 29, 2008 | Electrolux EW1000i Front Load Washer
Konica minolta opc drum magicolor 2350 printing problems I have replaced the opc drum on magicolor 2350 and also the black (k) ink cartridge and now can only really print in yellow, sometimes the other...
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
Jun 15, 2008 | Minolta Office Equipment & Supplies
Belt keeps coming off the pulley
I suggest you check your drum bearings, belt will only come off if misaligned.
Mar 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Creda W12oVW
hi m8 if the drum is solid then it could be the drum bearings which is a big job also check between the inner and outer drum to make sure there isnt nothing there
Nov 10, 2007 | Creda W120VW Front Load Washer
Hoover H110m help needed
hello sounds like the drum is stuck probebly the pole is cloged with hair and stuff if you have the skill open the machine and clean all while your at it look for the belt from the motor check her condition - bad? - install a new 1 there is a stretching unit for the belt 1) relese the bolt of this unit and change the belts 2) pull and stretch the new belt and then close the bolt good luck
Mar 20, 2006 | Hoover H120M Front Load Washer / Dryer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
164 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
