Question about Vacuums
Panasonic NN-SD776S microwave Start button stopped working. I know, the first thought is a bad door switch because "everyone knows a microwave should not turn on if the door is open." I am experienced with electronics, but even the timer won't start at all. Funny thing is, I had this exact model do this exact thing just over 2 years ago - troubleshot all the hardware until I was lost, finally bought a new one from Costco (June 4/08). And now 2 years later this one craps out - a 2 year timer on the keypad? As others have said, all buttons work except the Start button - even on the simple timer function. Any help?
  • 2 more comments
  • aaron541 Aug 24, 2010
    I have a hard time believing that the power supply can cause everything to work except the Start function - I can set the time, set other functions, but even the simple kitchen timer won't work - seems like the same circuit that would run the clock just fine would run the kitchen timer. Anyway, is there any place to find a schematic for this microwave?
    Also, how did this discussion end up in Vacuums? I'm pretty sure I selected small appliances when creating this.
    Just for fun, and while I was messing around, I recalled that this unit has a child lock function - looking in the manual to confirm, pressing the Start button 3 consecutive times enables the child lock, pressing the Stop/Clear button 3 times disables the child lock. The Start never beeps, does not enable the child lock, and generally does nothing. haha
    2 exactly the same units, purchased 2 years apart, fail with the exact same problem after almost the same time in service. Panasonic. Ugh.
    Quote from second last sentence of original post "...all buttons work except the Start button...". As for the model number, I'm embarrassed to say my dislexia burned me again - should be NN-SD677S - that shows up on the web. I apologize for the error.
    Boards - keypad connects via 9-conductor flex to display board (part #S-7A1AU), which connects via 17-conductor flex to the power supply and rotary encoder (for setting values) board (part #S-7A1DU). There are test points labeled with voltages, but I'm not sure what kind of tolerances the boards need (ie. TP shows 5v and I measure ~4.779).
    Truth be told I just had time to open the unit up tonight. Now that I have these front boards out I see what looks like water stains in a few areas - one being around the main flex connector of the display board (that connects to the power supply board). I can also see evidence that one transistor of the display board has been very warm - Q180, likely the power driver for the LCD so I expect it should get warm.
    Not sure where the moisture came from - the boards are behind the keypad matrix and front escutcheon. Don't think the cleaning lady dunked the whole thing in the sink. I will bring home some alcohol and acid brushes tomorrow and clean this up as a start.
    Looks like the keypad circuit feeds directly into the IC on the display board - Panasonic MN101C54CHX.
    I'll start with the cleaning, easy part, and go from there.
  • 905 Answers
Hello Aaron,
Since your microwave is controlled by logic, and the start button / timer portion is not working, I would start troubleshooting the power supply.
Get a look at the integrated circuits that are on the circuit board, and find their datasheets. From the datasheet, you can find the operating voltage. Then see what the power supply is putting out, and if it is different, find out why.
Posted on Aug 19, 2010
  • 1 more comment
  • Sheldon Dedek Aug 24, 2010
    You indicated that the "timer wont start at all" and Start button stopped working. You didn't say that all the other buttons were working.
    Given new data, try taking a look at the scan lines of the keyboard matrix.
    I am unable to find any information, including at Panasonic web site (owners manual), for your microwave. Can you confirm that the model# is accurate? Panasonic doesn't list it in the extensive series of microwaves.
    For a schematic, the PCB part number, if present, may be very helpful in perhaps locating a partial, or whole, schematic as part of patent process. Do you have the patent # as well, is there a separate number on the PCB?
    Your "water traces" could actually be flux residue. It is possible that water vapor from the oven cavity has condensed on the ribbon cable, but from your description, the cable goes -up- to the display board.
    In the manual, a demo mode is mentioned. This probably doesn't apply, but it is activated by pressing clock 3 times to turn on / off. Description indicates that power is removed from the oven for demonstration purposes. Not sure if it would disable the start button (probably not, since timer might be demonstrated).
    On the ribbon cable from key matrix, find the corresponding pins on the back side of the connector, or TP, or even via if they are used. You should be able to create a map / truth table of which line(s) change state when a button is pressed. It is possible that digital data is being sent as well. Given that there is a rotary knob, I would expect that Gray Code is being used on at least 3 of the lines, to indicate direction and increment / decrement, and a 4th line for setting clock. A function / truth table needs to be developed to understand how the key matrix is communicating to the control board.
    The power supply is giving you 4.77vdc off a 5v power supply. That is still within range of 5% (4.75min), and 10% (4.5min). Power supply isn't likely to be the issue (is there AC ripple on it?) since 5% is above the tolerance of most TTL active devices.
    The transistor that gets warm likely 1) drives the backlight for the display or 2) is a current source / sink. Since there are not any display problems, this is probably (just) within design tolerances regarding heat dissipation.
    No information, so far, has been found for the board part numbers. partstore.com lists individual components available for this microwave. Service manuals are also available for purchase, no luck on finding free to public though.
Panasonic vacuum cleaner just stopped running
Set the on/off switch to off, now check near the top of the "beater" portion, I think that model has a reset button, you should hear a slight "click" when depressed. Try turning the vacuum back on.
Aug 26, 2014 | Panasonic MC-V5217 Vacuum
Sharp r-530es microwave. when depressing door Pushbutton, the door will not open. (problem started itermittently but now will not open at all(unless I pull on the door to assist)
Hello there, the mechanism for opening microwaves is such that when the button is depressed it raises the hooks which hold the door back. In some microwaves the hooks also have another part which pushes the door out while some units have door hinges which have spring mechanisms which pushes out the door. Depending on what is obtainable on your unit the problem might differ. What you want to do is this, when the door is open press the button and see if the hooks which are supposed to hold the door in place move as expected but considering that the door opens when you pull the problem is more likely from the spring mechanism which is supposed to push the door out.
Try cleaning the hinges and the space in between the door and the control panel. Try this and let me know as any other process might require a replacement part.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Sep 21, 2011 | Sharp Vacuums
With microwave door shut oven continues to run
The door switch when closed seems to give a feedback to the processor which is triggering continuosly the circuit.
Please check on the board for insect secretion or dirt that seems to RUN the board when the door is shut.
Wash the board and replace, check the connectors to be tight and test.
if not there are errors in the board/ control panel which could be stuck with the start button in ON state. remove panel to confirm.
Aug 08, 2011 | Vacuums
I have a G.E 1.0 Microwave Model JES1039WF02, It has power on the panel but I see a message that says -F3- It will not start or do anything when the buttons are pressed. There is power running to it....
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
May 17, 2011 | Vacuums
I cannot find user manual for panasonic microwave NN 252 WBBPQ
Here is a link to the owner's manual for a Panasonic NN-S252 microwave:
http://service.us.panasonic.com/OPERMANPDF/NN-S262.PDF
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Thank you very much and good luck.
Joe.
May 16, 2011 | Panasonic Vacuums
The microwave will not work. I tried the power button, the timer, the food, none of the areas to touch on work.
the safety switch is burn or broken.
also check for roaches they like to hang inside a microwave, you be surpise that you might have no roaches, i said the same thing, til i found a few.
anyways, how old is the device if it like 4 years old might be curcuit board going bad.
touch pad might be bad. usually be better to buy another microwave then to get it replacable pad.
Oct 29, 2010 | Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
Dyson start button will not stay on. I have to
those switches go bad all the time. replace the switch and it will be fine. let me know if you need the switch
Jan 03, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
357 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
