Question about Canon PowerShot S51S Digital Camera
My lens is stuck and and keeps giving me the lens error message
    President:
  • 1,197 Answers
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Aug 20, 2010
Canon Powershot A1000 IS GIVING ME A "LENS ERROR, RESTART CAMERA" MESSAGE. I have restarted and the message keeps repeating and in both on and off condition the lens is not going inside.
Not a good sign my friend -- if the lens is stuck out then it's a shop-fix . Are you still in warrantee ?
The lens has a small motor on the PCB that pushes/pulls the lens into it's position. If this motor has broken then - sorry -- but it's very rare problem. Ray
Jan 25, 2011 | Canon Cameras
Lens stuck open ,
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error message. lens stuck open; gives a lens error message & must remove batteries to turn off
This seems to happen when something (water, sand, dust)
gets trapped in the lens mechanism.
Has the camera been somewhere filthy before?
The recommended methods include taping on the
bottom of the camera,rapping it on a table,
and pressing hard on the lens.
If the lens moves when you turn the camera on,
try keeping your hand on it so that i
t's forced back into the camera body.
A can of compressed air squirted around the
lens is also a possible fix...
but be super careful with that stuff,
a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff
to your camera, but if you're careful you may
be able to get it working again without having
to get it serviced.
Jul 06, 2009 | Nikon COOLPIX L10 Digital Camera
Lens stuck in out position
Replace the camera lens. Or take the camera apart, rebuild and clean the lens, then reinstall the camera lens into your camera. Rebuilding is not as fun as it sounds.
Nov 12, 2008 | HP Photosmart M527 Digital Camera
Need to know
unless you can get them free , don't waste you time on them
they were a cheap camera to start with
Apr 18, 2017 | Cameras
Lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 29, 2008 | Nikon Coolpix 5200 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Casio camera lens stuck
hi
this is repairable u ask ur near servicecenter
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
I fix digital cameras call 214-650-6531 or email me at mike@digitalcamrepair.com
Feb 06, 2008 | Casio Exilim EX-S500 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Canon PowerShot S51S Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
