Question about Sony Ericsson HBH-DS980 Wireless Headset
My headset got wet with sweat and i think that the battery shorted out. It now only works when plugged in. I have 2 other sony ericsson bluetooth headsets that were inundated during the great flood brought about by typhoone ketsana in the philippines. sony ericsson service centers here in the philippines don't service such devices, they only accept replacements under warranty. Could you suggest somewhere, anywhere, i can have it serviced and repaired. thanks.
  • 1,383 Answers
Try wrapping it in a towel placing it in the freezer for a few days, move it to the fridge for a day and then out in the partial sun, like a windowsill for a day or two, this will help pull out the moisture that is deep in the unit, it's worth a try. best of luck
Posted on Jun 15, 2017
SOURCE: pairing
read the manual page 64 bottom right corner
Posted on Jul 30, 2007
SOURCE: headset problem
no my speaker works my phone just thinks the headset is always connected
Posted on Jan 09, 2008
rudydanielle
SOURCE: bluetooth headset hb600 does not pair up to k800i
Hold down the volume buttons on the side till the button on the front turns red. Then try to pair, your phone should find it right away...put in 0000 and push connect on your phone. I just paired it with my iphone.
Posted on Jul 24, 2008
SOURCE: please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
Posted on Aug 03, 2008
ziraffa
  • 827 Answers
SOURCE: Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
LOST PASSWORD FOR SONY ERICSSON SGH-T469W BLUETOOTH HEADSET
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Mar 12, 2011 | Sony Ericsson Sony-Ericsson HBH608...
Sony ericsson bluetooth headset tryin yo connect
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
Bluetooth headset won't play music
hello,
All the bluetooth wireless headset are only capable of making/receiving voice calls.
Y?
its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
BT 1.2, Version playing music through a BT headset while music is playing on laptops.
and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
hope this little information helps.
TY
Nov 29, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericsson w610i
To unlock the phone I think is all 0s.
Oct 17, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Pairing Problem
It may be that the phone does not play music through bluetooth and that it only plays through the earphones that come with the phone. The only way to find out is to read the documentation on the phone or try another bluetooth headset, really. The headset cannot be faulty as it pairs correctly and it works with calls. Bluetooth headsets are not really intended for playing music as it drastically reduces battery life.
Sep 07, 2007 | Sony Ericsson Universal Bluetooth...
My phone is off but it wont turns on
Ensure the battery has a good charge on it, and attempt to turn the item on while plugged in to the charger. If this does not work, I would return it for a replacement.
Jun 09, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
Sony ericsson t610 is not charging
if the chocking coil that is placed bet charging fuse and charging input pin of UEM(universal energy management) is not working properly the set wont charge or else if protection anode is short circuited also device wont charge
Apr 20, 2007 | Sony Ericsson Mobile Bluetooth Car Kit...
Pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Sony Ericsson HBH-DS980 Wireless Headset Logo
610 people viewed this question
Top Sony Ericsson Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
sandrasteven
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
