Question about Kyocera FS-C5015N Laser Printer
My printer is printing the whole page in blue (the whole background is blue) it is still printing every other colour Ok, just that it prints blue over the whole page
Inkworks
  • 87 Answers
SOURCE: Gray background where printo on glossy paper 130g/m2
Be careful running "Glossy" paper through your laser printer. Make sure the paper package says that the paper is "Laser" paper. If your not careful the glossy part of the paper will melt on to your fuser leading to a major repair!
Inkworks
866-381-0541
Posted on Nov 07, 2008
SOURCE: Xerox 6250dp
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
Posted on Feb 27, 2009
  • 66 Answers
SOURCE: Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Posted on Sep 20, 2009
SOURCE: hp deskjet F4180 prints wrong
I had the same problem and the solution I found was to uninstall and then reinstall the printer driver. For some reason this worked. I now get the correct colors.
Posted on Dec 20, 2009
  • 164 Answers
SOURCE: black cartridge emptied half way
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most walmart pharmacy departments.
*Warning: You may want to usea pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Patience
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent aeound it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, slternately sloshing/swishing and pouring solvent over head (be carefull not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY,with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
Re Canon Mp470: all pages are coloured yellow when (the actual document printing is is ok.) colour printing. documents (office g) and web are fine
check the document settings to see if there is a background color box ticked
check in the printer settings for the same thing
Jun 04, 2016 | Canon PIXMA MP470 All-in-One Printer
Wont print in full black, does print in grey or any other colour.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
Apr 18, 2016 | Office Equipment & Supplies
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
R230 epson color
The cartridge head may have gotten clogged. Take the cartridge out and clean the head with a damp cloth and print a couple of pages to set this right.
Also, print a test page to make sure the ink hasn't dried up. If it has, you will have to get a new cartridge.
Aug 12, 2014 | Epson STYLUS R230 InkJet Photo Printer
Yellow not printing in Canon iP6600D printer
in the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Apr 29, 2013 | Canon Pixma iP6600D InkJet Photo Printer
I just replaced my old Printmaster with the 2011 Platinum. I designed business cards using the template from the list. But when I print, the cards are too large to fit on the page. I've tried reducing...
According to your problem you want print a business card and face the with font size & background
colour. It may caused your printer settings.
# First check your paper size in your printer propreties. It must be visiting card size.
# check printing resolution.
# printing quality in printing preferences should be suitable for a card printing.
for your second problem find the background graphics option in your printer properties and set it
properly.
For supported resolution, background image see ith product mannual
Dec 20, 2010 | Computers & Internet
I cant get my printer to print in colour
please use the colour printer ? and you have a colour printer
then your printer job is colour ? your printer cartries is colour & w&w ?
if colour ? then fristime you aply a print and so the print page is ok and so the previue the page in colour job if yes is ok and other no then
print page and in prperty selectand cleck and go immage in colour select the colour and aply the ok and give a print is ok
Sep 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Won't print correct colour
Try printing a test page. If it comes out missing colors, the you color cartridge is bad. HP test pages will print each of the 3 colors by them selves, so you can see if you are getting all colors. If this prints ok, the I would think it is not a printer problem.
Mar 06, 2009 | HP D1560 Deskjet Printer InkJet
Unwanted color printing
assuming you are using a browser have you gone to file page setup and uncheck the background printing of colors.
otherwise we need more info
OS , software application used, usb /network printer ,model printer
any changes made recently. etc..
Apr 02, 2008 | Computers & Internet
Kyocera FS-C5015N Laser Printer Logo
227 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
