Question about Goodman Heating & Cooling
Myair conditoner is not funtion or getting col air please tell me if is the compressor and how much is the value thanks
  • Goodman Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 19, 2010
Msh 30tv
You'll need a clamp on style ammeter to check it. On the data plate of the unit, look for the "LRA" Locked Rotor Amps value. Clamp the jaws of the ammeter around just one of the large black wires connected to the compressor and try starting the unit while observing the reading on the meter. If it's close to the value on the data plate, then your compressor is indeed locked. A bad start capacitor could be the culprit too
Dec 29, 2013 | Heating & Cooling
The compressor leaks air. The value on the bottom is really rustyI have hard to open it. How high do the compressor go before it shut off. I am thinkling to trade it in for a newer only. Thank You: Glenn
this valve is just a petcock valve and they are relatively inexpensive,as for pressure it will tell you on the compressor body tag,most are 130 to 160 LBS. in this size
Feb 09, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
PORTABLE AIR CONDITONER MODEL#APEOIAJMI-DOES NOT
If you turned this unit on right away after you received it you may haved damaged the compressor. You should always let a rfrigeration or a/c unit sit in its up right position for atleast 12 hrs. before operating, so that pressures and oil can equalize inside the system, unplug the unit and check the wires at the compressor and make sure they are still connected, Good luck.
Mar 05, 2010 | Heating & Cooling
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Sep 17, 2009 | Kenmore 8000 BTU Single Room Air...
Idk the model of my air conditoner I do know its a haier ac that's through a window and it doesn't seem to get cool it blows out hot air . Help
Do u feel that compressor is started after switched on ? If not pls. check temperature selector, Compressor starter capacitor.
Thanks
Aug 21, 2009 | Heating & Cooling
Air conditoning gets warm at idle. 1998 buick
It seems the automatic idling lifter (sensor) once you switch on the a AC system has failed and thus at low idling the Ac compressor clutch gives in stopping the compressor to spin.
You have to check tht system out.
Hope this helps!
Aug 04, 2009 | 1998 Buick LeSabre
Regarding the value to be know
Yes, you would do a LOOKUP do display the row number.
LOOKUP(H53,A1:G1000,0)
Feb 18, 2009 | Microsoft Computers & Internet
Getting cooler air
if you are desiring to have it 62 degrees in the house, the cool setting needs to be more to like 66 deg and the heat setting needs to be like 58 degrees. that would make it more around 62 degrees in the house.
change the heat setting first to 58 and then change the cool setting to 66. this gives your temperature 62 +/- 4 deg.
Jun 16, 2008 | Computers & Internet
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
