Question about EdgeStar AP14000HS Portable Air Conditioner
I have an Edgestar 14000HS air conditioner. My Water light is blinking when I plug it in and the STOP sign is flashing on the screen. I tried draining the water reservoir but nothing came out of the drain. I called customer service and they said the float valve was probably stuck. Has anybody had the same problem and fixed it and have any advice? Customer Service just said to call a small appliance repairman but I would rather fix it myself - doesn't sound like it should be that complicated.
2 Suggested Answers
  • 51 Answers
SOURCE: Hello.. I am looking for the bottom squirrel Cage
If you take off the back filter panel, you can look down into the innerds of the unit and you will see the squirrel cage.
Posted on Jul 10, 2010
Unit is off and displays blinking stop and won't come on...
My unit shut down in the middle of the night and had the blinking STOP on a dark screen, would beep 10 times when plugged in aswell. I set the unit on top of a pan and opened the bottom water drain plug. After draining alot of water out the unit allowed itself to be turned back on again. Guess its either extremely humid or the dual hose setup doesn't evaporate the water as fast as they made out. Anyways, I haven't found anyone else post this so I hope this helps someone out there.
Sep 26, 2012 | Haier 14,000-BTU Commercial Cool Portable...
Commercial cool air cond flashing stop sign and beeping
Mine was full of water. Undo the plugs in the back, drain. Clean air intake screen. Inspect to endure the radiator behind and below are clean.
May 16, 2012 | Haier CPN14XC9 Air Conditioner
The water light keeps coming on and kicking off the machine even after we empty it.
the float switch which sits down in the bucket may be stuck, try and find it and give it a wiggle to free it up.
will probably find it by removing the bucket and looking in the space where it normally sits.
cheers
Jul 03, 2010 | EdgeStar Portable Air Conditioner Heater
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Stopped pumpin heat displays E7
Follow the link below to find the information about your unit. Also, if you can't find the information that you need then they will have a way to get you the tech support that is brand specific.
http://www.edgestar.com/support/portableac.htm
Mar 20, 2009 | EdgeStar AP410HS Portable Air Conditioner
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar AP14000HS Portable Air Conditioner Logo
179 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
