Question about Honeywell ER150B Air Conditioner
The temperature in my apartment is not as cold as it should be. It doesn't match the temperature that I set.. how do I fix this?
  • Honeywell Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 19, 2010
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
When i select cold air, hot air is blown instead. When i select cold air with the AC, it is cold,and AC with hot air it is hot.
The thermostat controls the discharge temperature by using the compressor to cool and mixing hot water from the engine to match the setting. When you select AC, it enables the compressor to run from the thermostat. Else, only outdoor air is available.
Oct 09, 2013 | 2006 Ford Bantam 1.3i
Our fridge keeps freezing food
the recommended setting is usually right in the middle. If trying that setting doesn't resolve the problem, your cold control may be bad and not detecting the actual temperature and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Refrigerators
Temperature needle stays on the hot , have changed temperature sensor but it still stays on the hot and the engine is not overheating or leaking anything..what is making it stay on the hot
replace the thermostat,, and make sure that the fan engages , just because the fluids don't boil over doesn't mean the temp isn't to high, if your saying that the temp gauge is stuck on the hot setting, and doesn't move even when the car is cold,, thats a different problem,, if thats the case whats the make , model , and year
Sep 11, 2011 | Ford Thunderbird Cars & Trucks
Frigidaire gallery refrigerator ice maker doesn't turn off...no plastic signal bale arm?
Good day!!!!
When working properly, the thermostat turns the compressor on and off. Once the thermostat turns the compressor on, it will run until the temperature inside the refrigerator is lower than the setting of the thermostat. Make sure that the refrigerator has enough air clearance on all sides. Refrigerators with a condenser coil grid on the back of them need room to radiate the heat away from the coils.
Verify that the door light switch is working properly. Push the switch with your finger to verify the light is turning off. If the light stays on, it will actually warn the interior of the refrigerator. Fix or replace the switch if it is faulty.
Modern refrigerators that have a lot of storage and large freezer compartments run for longer periods of time. They also start and stop very frequently to maintain an even temperature. This is especially true if you have just put a lot of warm food in the refrigerator, or if it is very hot and humid. It can take several hours to get back to the cool temperature you have it set for after putting a large amount of food in it.
If the compressor is not shutting off when the temperature inside the refrigerator is cold enough, you may have a bad thermostat. You may also have the temperature set too high in the refrigerator. Try adjusting the thermostat to a lower temperature. If this turns the compressor off, you had it set too high. With the help of a refrigerator thermometer, you can find a more ideal setting that will keep your food cold, but not so cold that the compressor is always running. If raising the temperature setting doesn't help, it may be a problem with the thermostat and you will need to replace it.
If your thermostat is working properly, there's a chance that you have low levels of refrigerant in the sealed system. If this is where the symptoms lead you, you need to contact a professional appliance repair person. Only an EPA certified technician can legally work on a sealed system. If you attempt to do work on this system, you will void the warranty.
If this is a new refrigerator, it will run for a long time, almost constantly, before it gets cooled enough to stabilize the interior temperature. Allow up to 24 hours for it to stabilize. The refrigerator should be at least one half to two thirds full. This will help to maintain a stable temperature inside the unit. The cold items inside will help to keep an even temperature inside after the door has been opened and closed. Some people prefer to keep a lot of stuff in the refrigerator as ballast, even jugs of water. This helps to maintain temperatures inside so that when the door gets opened and closed often, it doesn't need to run as much to maintain the temperature inside.
I hope this information will be helpful...Thanks for using fixya...
Aug 31, 2011 | Refrigerators
My food in the refrigerator is freezing. How do I fix this? What are the temps that the fridge and freezer should be set on.
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Aug 21, 2011 | Maytag MFD2561HEQ Bottom Freezer French...
I have a Friedrich thru the wall air conditioner with a wall mounted thermostat but I cannot seem to regulate the temp. with the thermostat. What happens when I press the up and down arrows.....does the...
It is not uncommon for the room temperature and the set temp. on the thermostat to be several degrees apart. The room temperature should go down when you set the temperature on the thermostat down to a lower number.Hope this helps you and thanks.
Aug 17, 2011 | Friedrich Heating & Cooling
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
I have a WWA8827MALWH top load washer and the temperature settings dont match what they are supposed to be. i cant seem to get a cold/cold wash.and the other settings are mixed as well
Make sure the cold and hot water hoses are connected to the appropriate ports?  Also check to see that the filter screens in the hoses are not clogged.
May 19, 2009 | Washing Machines
Honeywell ER150B Air Conditioner Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
