Question about Frigidaire ATF6000ES Front Load Washer
The fabric softener area does not drain. What can I do to correct this problem?
  • Frigidaire Master
  • 43,501 Answers
This is on my to do lidt for writing a new tip...
Pull out the drawer and on the top left of the drawer tou will see a plastic tab that holds the drawer from coming all the way out. Push down on the tab and slide the drawer all the way out.
You will want to take the drawer to a sink and give it good scrubbing. Wash everything out, take the covers off of the bleach compartment and the fabris softener compartment. Clean out the holes with a toothpick in the tube that the cover sets on. That is were the siphon action takes place that pulls the bleach and fabric sofnter out of the cup of the drawer.
You also will want to wipe out behind the drawer while you have it apart.
Replace the drawer and you are back in business!!
heatman101
Posted on Aug 19, 2010
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
catriver
  • 878 Answers
SOURCE: Leaking // bleach/fabric softener dispener isnt emptying
Stara, sounds like you have a couple of issues going on here. On the model you posted there was a service flash on the dispensor. They redesigned it to provide an additional air gap for release. There was also a flash on the bleach hose splitting and leaking. The service flash numbers are 26-747 for the despensor and 26-746 for the hose leak. It almost sounds like your transmission is not going into it's nuetral drain. After completeing the agitation, it should drain for about 90 seconds before spinning. This would be a gearcase problem. The gearcase is covered for a period of 5 years, part only. You might want to check where you bought this unit and see if the parts are covered under warranty. Including the dispensor and hose. You would have to pay the labor..Hope this info helps
Posted on Jun 13, 2006
57 varieties
  • 1653 Answers
SOURCE: My bosch nexxt washer will not drain the fabric
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
beltronic205
  • 1466 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Fabric Softener Dispenser won't drain
It appears your dispenser's door latch solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
F3 error on my whirlpool washer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Oct 11, 2010 | Whirlpool Washing Machines
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
Aug 21, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Frontloader - the bit where you put the fabric softener in fills up with water and dosent drain. When I put fabric softerner in there it just stays there. Have pulled out the tray and cleaned it...
you can remove the top cover of the washer( 3 screws alongside the top rear of unit) and top will slide back and off, the dispensor is right there with sort of a tear drop shaped cam and lever.Make sure thats in tact. start the washer , and youll see it cycle foward and back if broken youll need to replace the part, dont think the line is blocked (if it was youd get fabric softener overflowing out front), im thinkin the water never gets to that area of dispensor. id start with the lever system
Mar 09, 2008 | Washing Machines
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Sep 03, 2006 | Kenmore 44102 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
325 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
