Hp D4260 My Hp 4260 prints from all applications except Word 97. When trying to print generates error message "winword.exe has generated an error" and closes Word 97. Same documents opened in say Open Office print OK
  • lvhp Jul 12, 2008
    I had the same problem and my related to when I set the printer to print in greyscale only.
  • Anonymous Oct 13, 2008
    Recently started this with a HP3600 that was previously ok.
I too have problem when printing multiple copies. Word just crashes out.
Any ideas how to fix???
Posted on Aug 07, 2008
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
MICROSOFT WORD 2010
I would recommend you to reinstall MS Word.
Feb 12, 2013 | Microsoft Word Home and Student 2010
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied...
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Dec 29, 2010 | Dymo LabelWriter 330 Thermal Printer
Cinemania97 and Windows 7
YOU DIRTY CINEMANIAC! don't you know we have IMDB now?!
ahem...yeah I still use Cin 97 too...the suggestion tool is great and I have all those old lists I spent HOURS on!
Firstly are you still using the actual CD-ROM disc itself? if NO skip the next part... if YES - the good news is that the program is easily copied to a HDD and runs superfast. Just open a window showing the contents of the disc and navigate to the DATA folder. This folder contains ALL the necessary files so copy it to any location you choose (eg C:\Cinemania)
double-click on the DATA folder and then the APP folder... see the file CNMNIA97.EXE? double-click it... Voila!
for some reason this .exe doesn't generate the error messages that the default launch file (CINMANIA.EXE) generates, so just create a shortcut that points to this file instead. DONE!
Cinemania 97 lists have a *.C7L extension - to use your old lists just find and copy these files to the location that Cinemania keeps its newly created .C7L files under Win 7.
Create a new list and search for *.C7L - for me the path is: C:\Users\YourName\AppData\Local\VirtualStore\Program Files (x86)\Microsoft Multimedia\Cinemania
Jun 25, 2010 | Microsoft Cinemania 97 Full Version for PC
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
I get an error message when I turn my computer on. HP Connection XP.exe Common Language Runtime Debugging Services. Application has generated an exception that could not be handled Ok to terminate, Cancel...
Hello and thank you for using Fixya's services.
HP Connection XP is a program that is installed on your HP computer for assistance and support. If your computer is over a year old, I would suggest removing the HP assistance. You can do this by going to the control panel and selecting add/remove programs. You are looking for HP help, HP assistance, HP remote or HP support. Unintsall this program and you will rid this once and for all.
Please let me know if you have any questions.
Nov 04, 2009 | HP Computers & Internet
I'm trying to print a standard #10 envelope using the HP photosmart 7660. Getting error message that the paper is too small; load larger paper.
What application are you using to generate the document, Word, WordPerfect?
Check the "Page Setup" menu from within the application to make sure that you have the correct page size selected in the application.
Don
Oct 22, 2009 | Office Equipment & Supplies
I have a dell latitude es400 and it keeps giving me a error messages like drwtsn32.exe-application error. The message in the box shows "the application failed to initialize properly (Oxc0000142). Click on...
You can reinstall the entire operative system with the CD that comes with your laptop, or with the restoration partition. See user's manual. This is the best way to fix error in a PC. Before restore the OS, backup your personal data.
May 14, 2009 | Computers & Internet
269 people viewed this question
k24674
jasbo
jasbo
