Question about Weather King 10AJA6001AH Air Conditioner
HOW TO REPLACE BLOWN TERMINALS ON COMPRESSOR?
    President:
  • 3,773 Answers
They're not replaceable!
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 19, 2010
Maytag French Door Compressor not starting. Replaced burnt Start Relay and Capacitor. New JazzBoard. Compressor still won't kick on. Is there a Fuse that may have blown when the Relay burnt up ?
take out the terminal and check the power is coming to the compressor terminals and if it does then its overload or control board is faulty too.
Oct 03, 2016 | Maytag Refrigerators
Freezer won t freeze
either mix too rich, torque set too low, shaft spring bent, compressor relay blown, compressor contactor shorted, refrigeration valve solenoid bad, or filter dirty thus reducing air flow. if it's both sides, clean the filter and check the compressor relay (behind right side panel, behind plastic cover on compressor. if you smell burning electric, replace) and the contactor (behind right side panel at the top, tan box with wires. press the tiny button to start compressor. if it doesn't start, replace). if it's only one side, check the valve solenoid (inside left side panel, there are 2 valves. remove plugs from each and retouch to terminals while on. if they click, they work).
Jan 17, 2014 | Bunn Kitchen Appliances - Others
Outside an turns but the compressor will not come on
If you have an oil smell more than likely your compressor has blown it's terminals and the compressor has to be changed.
Jul 24, 2012 | Goodman Heating & Cooling
A/C compressor on 95 astro van does not engage at all.
There are a few reasons for the compressor not engaging. Lets start with the most common. low ac gas.A bad clutch on the compressor.Blown fuse.
Let is start with testing for low gas. (134a freon).Locate the dryer. this is on the passenger side of engine compartment. it looks like a tall cylinder, on the top side you will see a switch. unplug switch connector and jump the two terminals in connector with a piece of wire, this is the low pressure or cycling switch. you will be completing the circuit by jumping a wire across the terminals.If the compressor turns on when connectors are jumped then you are low on gas and the system needs recharging.
If the compressor does not urn on then check all fuses, if fuses are good then the next step is to go to compressor and test for power and ground. If you have power and a good ground on the connector to compressor then compressor clutch is bad.A bad clutch will some times blown fuses, so if you replace the fuse because it was blown and it blows again then clutch is bad.
Another test that will help is when you remove the connector from the cycling low pressure switch , test the connector. one wire on the connector should have power when ac is turned on,
Hope this helps let me know what the outcome is. Good day.
I have enclosed a picture of the switch and dryer to help you locate it.If you jump the terminals
Mar 23, 2012 | 1995 Chevrolet Astro
There is a clicking sound like something is trying to turn on, the freezer has quit cooling and now the frig is begining to shut down what can it be?
How To Replace the Compressor Relay The compressor relay is accessed from the lower rear of the refrigerator. The compressor relay is located in the terminal box which on the side of the compressor.
Before replacing the compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced
Reattach the wire to the new compressor relay and press the relay back onto the compressor terminals. Replace the terminal cover box and plug in the refrigerator.
Aug 18, 2011 | GE GSS20IEP Side by Side Refrigerator
Compressor makes a buzing sound and then clicks off.
Change the start relay.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by a tension spring or with a retaining clip.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor. Remove the compressor relay by pulling it straight off from the compressor.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced.
Jun 03, 2011 | Refrigerators
Have a 4horsepower neo plasma split that keeps tripping out the fuse in the meter box.have had air con guy out and he says the 14 amp fuse is not sufficient for this air con even though it has run on it...
Please note your fuse wire must be 2 to 3 times of running amps. Suppose running amps is 6.5, the fuse wire must be minimum 15 and maximum 20 amps. Always choose the maximum.
Other chances for fuse blown;
And in your a/c, If your fuse tripped as soon as compressor starts, check compressor winding with ohms. In between 2 terminal it should be equal in 3 phase compressor. In single phase compressor, SR must be the total of other two.If any huge difference it means winding weak. If any ohms reads between any terminal and grounding it means compressor grounded for which you have to replace compressor.
Hope, it's helpful?
Jan 27, 2011 | LG LS090HE Split System Air Conditioner
Fuse blown when a/c switched on.Carrier window a/c.
Compressor may be grounded. Remove all wires from terminal of compressor. And check ohms with terminal and ground. If anything reads, it's grounded. Replace compressor.Helpful?
Jan 20, 2011 | Heating & Cooling
My dog chewed the thermostat wire by the compressor, i replaced the chewed wire now the thermostat won't turn on, therefore; no ac.. could it have blown a fuse? if so, where are they?
Either you have blown the low voltage fuse located inside the air handler (if there is one) or you have blown the transformer feeding the low voltage control wiring.
If the transformer is blown due to no fuse installed, I would recommend installing a low voltage 3A fuse in line with the red terminal coming off the transformer. This will protect the transformer in the future.
Aug 01, 2010 | Goodman CKL42AR42 Air Conditioner
Neither fan or compressor will com on
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Jun 17, 2008 | Dometic Rooftop RV Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
48 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
