Question about Dell 3100cn Laser Printer
Dell 3100cn Laser Printer - Not capable of duplex printing? Or yes?
  • 560 Answers
Hi. Duplex printing is optional. You need to purchase additional accessories to enable duplex printing.
Posted on Aug 19, 2010
Getting an error message 016-799
One reason this error message is displayed on Dell laser printers ... attempting to duplex print using the Single Sheet Feeder (SSF). Try printing document single sided if using the SSF.
Mar 15, 2014 | Dell 3100cn Laser Printer
My dell 3100cn won't print, even though it says the printer is ready
look inside of printer.see if something is pulled or unpluged. see if there is ink and paper inside.
Jun 20, 2013 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
I have a delll laser printer 3100cn and I want to print labels and I insert them and it will not print
You need to specify from your computer that you want to print to the MPF tray.
Jan 04, 2009 | Dell 3100cn Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Linux printing with Dell 3100CN
OP provides the solution! (BTW, I'm able to print to this printer from MacOS too.)
May 01, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
302 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
