Question about Whirlpool LER6636PW Electric Dryer
Damp clothes Hello, we just moved into a new house, well it's about 2 years old..my husband had to replace the electric cord on our old dryer to fit a four prong outlet. The problem was the dryer seemed to be heating and runnig fine but our clothes were left damp, really damp. We took the dryer in and they couldn't find anything wrong with it, so my husband took it apart and we just figured we needed a new dryer. So now we have a brand new dryer and we still have the same problem it's heating and it's running fine...but the clothes stay wet. Help!!
    Genius:
  • 1,073 Answers
The dryer is not the problem the problem is the house vent it is restricted some where
Posted on May 03, 2008
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Hello, I am replacing a 15+ year Frigidaire
these are usually 220 volts.If the grey cord has three prongs on it it will be 220.
Mar 17, 2010 | Frigidaire FEX831CS Top Load Stacked...
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Whirlpool Duet Electric Dryer
make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Feb 17, 2009 | Whirlpool GEW9250 Electric Dryer
Could it be the heating element/coils?
From the info you've given, I'd suggest confirming whether the electrical circuit breaker arrangement for the dryer is single-pole (one wire and handle, 120V) or two-pole (2 wires and handles, 240V).  The heating element requires 240V.  Also, you mentioned a "fuse box". Hopefully you meant circuit breaker panel.  The wiring in any house old enough to have fuses instead of breakers would be a major concern unless you're into indoor barbeques in the middle of the night.
Jan 31, 2009 | GE DBXR463EBWW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Rusty Drum!
you can extend the life for a little, by painting with a rustolum paint, but not for to long, better buy a good new one, use your experience when select the new one...good luck
Aug 07, 2006 | Zanussi TC7114W Electric Dryer
Whirlpool LER6636PW Electric Dryer Logo
258 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
