Question about Ingersoll Rand Electrical Supplies
I have a 50KW ingersoll rand Gen. and the motor just went up in smoke. the Gen set is fine I want to unmarry the motor from the genset How?
    Scholar:
  • 97 Answers
To break the marriage of the units there should be a screen holes on the gen head remove the screen and look inside there are 2 type of mountings 1 is a rubberized gear looking spline this is a damage for shock loads from the engine they just slide out the other #2 is a flex plate type with bolts to the engine fly wheel you need to remove these bolts you will have to rotate the engine some times to get to them all when this is done at the bottom inside the ger use wood shins between the armature and the commutator the metal parts be careful for to damage the windings some times the access holes have a alignment where you can place a shaft and run under the gen head shaft to support it then unbolt the gen head from the engine bell housing wrap the gen with plastic till a new engine is ready to install hope this helps
Posted on Aug 31, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
Motor start capacitor on my ingasolll copresser smokes
It has died. Get a new one before you burn up the start winding in the motor. Check the centrifugal switch in the motor to see if it turns off the capasitor once the motor picks up speed.
Dec 31, 2013 | Ingersoll Rand Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
VSD Fault 23
Vsd 23 is a motor under speed problem. Check motor turnes ok, if not it could be a number if faults including the hall effect sensor that detect motor speed, you will need to call a Ingersoll Rand technicion in to do a 348 diagnostic test.
Apr 18, 2012 | Ingersoll Rand Air Tools & Compressors
I have a 50KW genset and I am in need of a new radiator, could you point me in the right direction?
There should be a tag on the radiator of who the radiator manufacturer is and they should be able to supply you with a replacement or try contacting an Ingersoll Rand distributor for help http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31039.
Jul 05, 2011 | Ingersoll Rand Electrical Supplies
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Mar 15, 2010 | Ingersoll Rand - Rand Type - 30...
Electrical Supplies Logo
227 people viewed this question
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
