Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Kenmore freezer my freezer condenser is not accessible so how do I determine if it is dirty and the possible cause for my freezer not freezing
    Scholar:
  • 149 Answers
The condenser is usually located on the bottom removing a small panel on the behind or its a black grille behind the unit
Posted on May 05, 2008
  • Alexander  Figueroa
    Alexander Figueroa May 09, 2008
    also theres a panel where the controls are you can take about 4 screws out and there should be the compressor and atleast from there you can trace the piping.
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezer staying off for too long
This sounds like a defective start relay overload and capacitor if your model has one. When a compressor short cycles it causes the symptoms that you described. Short cycling can be caused by the parts I listed and a defective condenser fan or dirty condenser coils can cause the defective start components. What is your model number? Sea Breeze
Mar 07, 2013 | Freezers
Ec 08
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Dec 03, 2012 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Kenmore side by side, freezer section is not freezing. Ice is melting. Refrigerator side seems to be working. I do not hear any noise from refrige/freezer.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 21, 2011 | Kenmore Freezers
Freezer used to freeze..
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 01, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Unit Isn't Functioning
Inside the refrigeration system alot is goning on. You have to check the pressures low/high to determine the problem. It is easy to say that your unit needs freon but that is not always the case.
here is a list of possible problems:
dirty condenser
dirty evapoator
fans not working
defrost not working
lost of freon
bad compressor
bad compressor valves
slugging
flooding
lack of oil
super heat off
txv is stuck open/close not sensing
incompatilbe unknown freon mix...
well these are just some of the problems you can encounter. this was meant to tell not fix because each problem needs attention but hope this was a little helpful anyways
Mar 29, 2010 | Traulsen 69.1 cu. ft. / 1957 liter...
Subzero bottom freezer dont freez well and dial is to the maximum
Possible problems:
frost build up on the back panel.
freezer fan not working
compressor low on freon
defrost not working
dirty condenser
condenser fan not running
try to see if you can figure which one (or not)
then let me know
Mar 29, 2010 | Freezers
Whirlpool upright freezer- model EEV151N is running but not keeping things frozen. Making a whirring noise louder than usual. At least 24 years old.
Possibly has a restricted capillary tube. Possibly has a extremely dirty condenser coil. Possibly has a bad compressor which will run but has bad valves so it doesnt actually pump the refrigerant. If the condenser coil has a fan (unlikely) it may be dead and causing the unit to run much higher pressures than normal which could cause this. Only thing you really could do would be clean the condenser coil. Anything else would need to be repaired by an Refrigeration Mechanic.
Oct 10, 2009 | Whirlpool Upright Freezer EV161NZRQ
Not freezing
check to see if your condenser is dirty, that can be the problem if looks clean, suspect low refrigerant charge
Mar 19, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
93 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
