Question about Maytag MEC5430BDS Electric Cooktop
How do you wire the cooktop to the main power source. There are bare wires coming out of the cooktop..red black white and ground.
  • Maytag Master
  • 43,501 Answers
The wire coming in should have the same colors, just match up the wire colors and wire nut them together with large wire nuts ad them tape them. ground the green wire to the ground screw.
That's all there is to it!
heatman101
Posted on Aug 21, 2010
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Which from the red or the black wire comeing from the stove, is the hot one
Since you have a red wire you must have 10-3 romex. 10-3 has four wires. Three jacketed wires Red, Black, White and a bare copper wire. The is Red and Black are your two 120 legs (both hot) white is neutral and the bare is ground.
Jul 13, 2011 | Whirlpool RCC3024 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
Hello: I am trying to replace a cooktop (installing a used cooktop - GE model# J P651 002 AD). My problem is making sure I understand the wiring connections. The cooktop has a black, a red, and a green...
The green goes to the bare ONLY.
Likely the black was used as a neutral and the reds were 240 volts.
You need to investigate at your panel. If you see the black going to the neutral bar, abandon it by capping with wire nut. If you see both the reds going to adjacent terminals on a double breaker, connect one red to the red and the other red to the black of the cooktop,
Oct 07, 2009 | GE 30 in. JP328 Electric Cooktop
I have 4 wires from the cook top and a black, white, and bare from the breaker. No instructions. My guess is white to white, green to bare, and black and red to black. Don't want to guess.
if it's 240volts and you have from the cooktop a red/black/white and green red&black are the two hot wires 120+120=240volts/white is the neutral/and green is safety ground-------as for the breaker wiresblack and white are the hot wires and the bare wire is the neutral it really shouldn't be a bare wire because even if it comes directly from the main house panel it does carry current,and by the n.e.c. white can't be used to carry power,unless it's marked at all visible locations with any color but green/check those wires and see what voltages you have before wiring to unit
Aug 08, 2009 | Cooktops
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Nov 07, 2008 | Cooktops
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Sep 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Maytag MEC5430BDS Electric Cooktop Logo
271 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
