Question about ASUS M2N-MX Motherboard
NO SOUND IN HEADPHONE WITH WINDOW 7,BUT WITH XP SOUND COMES,WHY & HOW CAN I PLAY HEADPHONE WITH WINDOW 7,
    Scholar:
  • 83 Answers
In the sound manager option try to uncheck the microphone option.
Posted on Aug 19, 2010
Intel(R) Desktop Board D945GCL,Window 7 ultimate is installed.After installing Audio Driver (Version 5.10.5208.0) Sigma High Defination Codec,in speaker properties,Jack is showing Jack information not...
Please ensure that your bios setting is enabled for audio.
1. Have you installed the correct windows 7 driver or have you configured with the vista driver?
2. If you have installed with windows 7 driver, check it for 32 bit or 64 bit and you are installed perfectly!
3. Check the windows service. Go to "run", type "services.msc" and press enter. In that opened window, direct to "windows audio". Open it and check the service is started or not. Also ensure that the startup type is set to be "automatic".
Hoping you will be short out!
Aug 19, 2011 | Intel D945GCL Motherboard
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Not recognizing Headphone or handsfree
Go to the manufacturer website and see if they have windows XP drivers if not it may not work.
May 15, 2010 | HP Compaq 6720s Notebook
Headphone jack works but no sound
I had this problem too, only there was zero sound, even when I clicked Test. I know the jack is good because it's never done any of the typical crackling or cutting out when the cord is pulled in a certain direction, etc. - I knew it had to be a setting of some kind. So here's how I solved this particular problem:
[N.B. - This is in Windows 7 OS]
I went into Control Panel -> Hardware & Sound -> Sound -> Manage Audio Devices.
In the popup window's Playback tab (which comes up by default,) I right-clicked on Headphones, then clicked Properties. The new popup window's General tab comes up as default; I clicked on the Levels tab, where there's a slider control for headphone volume. For whatever reason, this was set to 0. I changed it to 100 and I immediately got sound. 'Clicked OK, and exited Control Panel.
Apr 09, 2010 | Toshiba Satellite A215-S4747 Notebook
Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
Mar 07, 2010 | Music
No HD audio via HDMI after upgrading to Windows 7.
Hi, pls go to control panel/sound & audio devices. Then select your output audio device there. It's probably set on your headphone I think. If you are getting audio from headphone , this means that the audio driver is installed.
Pls contact me for further info.
Feb 10, 2010 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
Audio driver jack & sound control not working properly
Greetings,
This means that their is a sound indicator but no sound comes out from your headphone.
I want you to double click the speaker icon found at the bottom of your task bar, along with the time and other icon.
A dialog box will appear, un-check all the option found on that window, add also some option by clicking the file options.
Thanks again.
Nov 05, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Cannot control sound when booting...
Sohanad, look in control panel under sounds. There a setting in there that you might have to check/uncheck, inorder not to hear sound when headphone are used.
Apr 28, 2008 | Compaq Audio card Sound Card
ASUS M2N-MX Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
