Question about NetGear Computers & Internet
When keying in the pin or key # do you have to use upper case and lower case letters
    President:
  • 1,768 Answers
.if you are referring to the security key it depends on how you set it up in the security wizard at the initial setup
Security key can be setup with upper and lower case unless the manufacturer has specific rules for typing in the security key.
Posted on Aug 19, 2010
How do i do upper and lower numbers on my computer ,i am a learner
Upper and lower numbers, or letters? I don't know anything about lower numbers. But you press the shift key or take off the caps lock to change from upper to lower case and vice-versa.
Feb 27, 2015 | Toys
My smith corona sl 570 is not printing the letters c,v, b and n in both lower case and upper case. how can i fix this?
You have a key board problem. It may just need disassembly and cleaning but more likely it needs a new contact velum.
DickyO
Jan 03, 2014 | Smith Corona Wordsmith 100 Typewriter
What is the fn key
I suspect this is a message you're seeing on a notebook, computer or other device that has a keyboard. The "Fn" key is the "Function" key. When the "Fn" key pressed at the same time another key is pressed - in this case the F4 key, a different result will occur when compared to pressing the F4 alone. This works the same way as when you use the SHIFT key and a letter key - instead of a lower case letter, you get an upper case letter.
Typically, the keys on the keyboard are labeled in a light color. Keys that have a second purpose or function, will have a second label printed in a different color / slight smaller text or both. This label may be text or an icon or graphic. In order to invoke the second function of the F4 key, you will need to inspect the keyboard for the key that has is labeled with "Fn" text on it. Here's what a typical "Fn" key looks like:
The Fn key is in the lower left corner of this keyboard.
I hope this answered your quiestion and good luck!
Jan 04, 2013 | Epson Office Equipment & Supplies
Capital letters are low compared to lower case letters
You probably have old rubber stops on the shift that have gotton soft or hard over the years and need replaced.
DickyO
May 15, 2012 | Office Equipment & Supplies
WHEN YOU PRESS THE CAPS LOCK BUTTON YOU HAVE THE CHOICE OF UPPER AND LOWER CASE LETTERING BUT THERE IS ALSO AN ARROW BUTTON WHICH IS TURNED OFF AND I AM NOT ABLE TO TURN IT OFF IT SEEMS TO HAVE REVERSED MY...
That UP arrow refers to an UPPER CASE letter. If ever you press the CAPS LOCK key, it should turn off, if it does not it means the CAPS LOCK key for some reason is stuck. Try restarting the computer and by then the CAPS LOCK should be disabled.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 | Gateway 2520915 Keyboard
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My shift key is not working properly in my Keyboarding online class. It gives me an error everytime I try to key in a capital letter. i have changed keyboards and it still does the same thing.
When you say it gives you an error, do you mean an actual error message, or the lower-case letter?
I have no idea what your experience is, so I'm asking if you know the difference between the Caps Lock key and the Shift key? The Shift key has to be held down while pressing the other key, eg h key to get H.
Pressing the Caps Lock key locks into upper-case, SO YOU GET A LINE LIKE THIS until you press it again.
Apr 08, 2010 | Computers & Internet
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I purchased enterprise 2007 and loaded it onto my computer. Now I am trying to use the product key for my laptop but it keeps saying invalid key
First, do not post the key or your product be disabled.
The key is not on the outside of the package.
Use caps. Watch out for the Letters I L O
The letter "O" is a full round letter. The numeral zero "0" is more narrow.
The number 1 looks like the upper case I (eye)
The uppercase I is not a lower case L
I hope this makes sense.
Oct 09, 2009 | Microsoft Office 2007 Basic for PC
Cant type upper case letters
If your caps lock is not working, a best alternative would be to hold down the shift key while pressing a letter and it will convert lower case to upper case.
Sounds like a new keyboard may be in the future for you.
Sep 01, 2008 | Computers & Internet
Computers & Internet Logo
177 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
