Question about Microwave Ovens
White-Westinghouse side by side refrigerator, 30 years old....Recently we noticed that if the compressor was off and we open and closed the refrigerator door. the compressor would try to come on only with a kind of chattering/clicking noise and then no absolute quiet for for a minute or so, then a repeat of the noise. Suspect either was the auto circuit breaker or the contactor was having an issue. Eventually the compressor comes on and it cools as expected.
  • Gerald Gier Aug 19, 2010
    Supper.....that is sort of what I expected but wanted to get a expert validation......Thanks a load....Your a great American
  • 6,784 Answers
HI. There is a start overload relay switch that is attached to the compressor unit. This relay receives the duty signal from the main PCB and door switches. The door switches provide the open and closed circuit. Once the doors are closed, the PCB will then route the power signal to the compressor, via relay switch. If the relay experiences difficulties with the current, it will emit a clicking noise, thus, indicating a mechanical breakdown within the relay itself. This will be the culprit. You will need to replace that start relay. Once it is replaced, the unit will run as designed.
With that said; it would be wise to test the door switch circuit for faults before replacing the relay. There could be a short with in the door switch. Follow the switch test below to isolate the relay
Refrigerator door switch testing procedure:.
Gain access to the door switches terminals and follow the procedure as follows:
Test the switch for continuity by using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
If the door switch(s) passes the above test; Replace the start relay that is mounted on the compressor unit.
Posted on Aug 19, 2010
White westinghouse range
A model number would help, but if it's really old, information may not be available.
If this is a simple mechanical lock which you're supposed to be able to lock and unlock by hand, maybe it's rusted. A penetrating oil like PB Blaster may help.
If it's a relay-drive lock that's controlled by the circuit board, then it may need board repair, etc.
Jun 08, 2013 | Microwave Ovens
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
I have a ten year old Amana bottom freezer refrigerator bx21v1c,and the compressor has died. I am debating as to whether to buy a new refrigerator or to pay up to $800 to replace the compressor.
There is no way that I would spend $800.00 on a ten year old fridge... I can do my own and I would not replace a compressor on a ten year old unit...too many problems afterward...too many other things that could go wrong shortly...
You will be better off to take the $800.00 and put it towards a new unit...
heatman101
Jun 10, 2011 | Microwave Ovens
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble...
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Jan 13, 2011 | Microwave Ovens
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Microwave oven turns off
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
It may be worth getting it repaired. Shop around for prices and see if it is worth your while to repair it or simply buy a new one :)
Sep 29, 2008 | Microwave Ovens
Microwave shuts off about 10 - 30 after starting to heat an item. Display flashes PF. Which I figure is power failure. Unit is 5 months old and has very little use. Model WES1130DM1WW purchased at...
It should have a one year warranty, right? If so, Westinghouse should take care of it for you.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 21, 2008 | Microwave Ovens
Microwave repair, 6 year old White-Westinghouse WW1000
High voltage parts: Capacitor, Diode, Magnatron are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 09, 2008 | Microwave Ovens
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
