Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore 795.755744 I have a Kenmore trio and ice is building up on the bottom of the freezer floor underneath the bin. I've been told to empty the entire unit, unplug it and wait for the water line to drain as it's probably frozen over. Is this correct and is there any way I can check from the inside of the freezer? I can't get behind it as the water line is almost fully extended from the wall. Thanks!
  • harleyjoe03 Jul 22, 2008
    Problem started two monts ago - water puddling and freezing on bottom of freezer. I replaced the entire ice making unit (adjusta cube - sears out sources their parts). The water still pooled at bottom. I removed the back panel inside freezer and saw the drip tray under the coil was frozen and caked up with ice. I removed the panel on the rear /bottom of the refridgerator and found the drain hose next to the water solenoid/pump. I blew compressed air into it and hopefully solved the problem (if in fact it was blocked)
I have a trio 7755 and had this problem within 6 months of ownership. It was the valves that fill the ice trays not completely closing when tray is filled (continued to drip--building up an ice block on the back wall and in the ice tray. I replaced the set of valves in the lower right (when looking at the back of the fridge). Problem solved, has worked perfectly since.
Posted on Jul 14, 2008
Whirlpool refrigerator ED5RHEXMT00 makes plenty of ice but is not dispensing any when the door lever is pressed. The water part is fine.
The ice bin slides down in little tracks and the drive mechanism engages the auger. It sounds like you have frost build-up in the bottom of the little slots that the ice bin rests in. The build-up keeps the drive from engaging the auger. I use a hair dryer to defrost all the accumulation under the bin once it is removed. Remove the bin by tilting out and then lifting up and out at an angle. Also empty the bin of ice cubes and check underneath for ice build up on the bottom of it too.
Dec 10, 2014 | Whirlpool Refrigerators
Glide rails on kenmore bottom drawer freezer keep freezing up
I suspect that you've got a leaky ice maker. Do you have clumps of ice in the bin, too? Many times, replacing the ice maker will solve the problem.
Jul 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The bottom of the freezer keeps getting a layer of ice. I take the ice out about once a week. Now there is so much ice that it is leaking water on to the floor before it freezes. We have a Kenmore elite...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 13, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
