SOURCE: My LG Xenon GR500 is showing that my sim card
Try removing the battery and then the SIM after the phone has been powered on. If it still gives you an error, your SIM may be bad. Try swapping SIMs with a friend on the same network to test. If the SIM is bad, or the phone still doesn't work, call your provider to find a local repair facility for the phone.
SOURCE: How do I format a memory card for a LG Xenon GR500
Go to Top Menu > Settings > More > Connection > USB Connection Select 'Mass Storage'. This enables Windows to see the Micro SD card in your phone as a storage drive and you will no longer get the format message when you plug your phone in to your PC. After this I was able to drop mp3 files into my phone and use them as ring tones.
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
