Question about Casio PRG-40T-7 Pathfinder
How to use all finctions of prg 40 - Casio PRG-40T-7 Pathfinder
  • 831 Answers
You can download a manual/instr from their website. You will have to enter in your country/ model info, etc. Heres the link:
http://www.casio.com/
Posted on Aug 19, 2010
Casio PRG-80L reads open
Have the same problem, Casio PRG-80L reads open. No hints about this in the manual. Nor did Votit's suggestion help. Note that although the watch is old there is clearly power left in the capacitor battery. Ended up accidently ito this mode when resetting the time. Assume the open mode is intended for service, but would just like to exit.
Nov 03, 2012 | Casio PRG-40T-7 Pathfinder
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
Battery replacement
You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
Good luck.
Do not forget to rate, please.
Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
Changed dead batteries on PAG-40. Still one dead watch
There is a very small sticker with very small red print just adjacent to the battery compartment. This little sticker states "once batteries are replaced, you need to touch AC with tweezers". I did it with metal tweezers and the watch display came to life. Good luck!
Jan 15, 2009 | Casio PRG-40T-7 Pathfinder
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Chabging the batterys on the prg 40
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
Casio PRG-40T-7 Pathfinder Logo
185 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
