No Picture but have sound
The TV is 6 years old. One day we switched it on and there was no picture but we could hear the sound. When we switch it off there is a horizontal white bar that flashes on the screen for a second. I would like to fix it as the TV has been great so far. Please help! No picture but can hear sound
OK I got my first TV, first to repair myself that is, and I have no training at all but am kind of a tech dork wannabe. So I checked and I have sound but no signal through the TV tuner, so I hooked up my Zenith VCR to aux 1 and sound with signal appeared, the VCR tuner still works :) so I am leaning toward the TV tuner. It is visibly damaged, and I'm hoping it is as simple as a broken connection. I also noticed a vertical flash and pattern of horizontal lines when it is turned off (white). sooooo I push on.... help!!!!!!!!!!!!! :>}
Posted on May 03, 2008
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
Luxor tv no picture or sound
Connect the TV to another power outlet that you are sure, works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
When powered on with remote,makes usual sound,green light comes on,then goes off,blinks 3 times,goes off and contiuesly blinks until unplugged. Problem is picture suddenly went black with no sound.Could it...
my samsung tv model number is sp50L7hx it's 6 years old, when I turn it on it's a not really nice picture just nice sound, after 2 hours the picture is off just sound .... after I was switch off TV and switch on again ... the picture is very bad and just for a ten-twenty minutes ... what's is the problem? I'm never change the lump ... or is it a some problem with T-Con decoders board or is it a lump?
Jun 19, 2011 | Televison & Video
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Jun 08, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Tv has sound but no picture
Sounds like you have lost video somewhere in the video circuits. Possibly the picture tube could have gone bad or lost filiament voltage. You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as the high voltage. Stargazer
Jan 24, 2007 | RCA G36710 36" TV
RELACED THE VERTICAL OUTPUT IC ALONG WITH THE CAPACITOR AROUND IT.6 YEARS IS ENOUGH FOR THE CAPACITOR 2 DRIED UP THIS CAUSE FAILURE TO THE IC...
Jun 28, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
