Question about Kohler Home
Our 25 year old Kohler bathroom spa has a digital control pad and the pad has stopped working. The minutes do not show up in the window and of course start and stop buttons do not work. HELP!
Why has my heated mattress pad stopped working?
Electronics fail. Sounds like the digital controller has failed. A Google search finds others with the same problem. Biddeford models come with a 5-year warranty, so if yours is less than 5 years old, I suggest you contact Biddeford by telephone: 800.789.6441 or visit their website: http://www.biddefordblankets.com/warranty.asp
Sep 15, 2014 | Biddeford Blankets Heated Mattress Pad...
I have a Nikon Coolpix S3 which I have been using for the last 4.5 years. Recently it has started showing an issue that the display goes blank and the camera stops responding after a couple of shots. I...
I cannot be sure but a 4.5 year old camera 'may' have an old battery. Meaning you charge it to 100% and it has something like 25% total capacity. (Especially if you used the camera a lot) You never see a battery indicator on the display when shooting... like 5 minutes after you charge
Dec 25, 2017 | Nikon Coolpix S3 Digital Camera
I have compaq 610 laptop window7 . frequently external usb mouse stopping to work as well as showing that one usb device attached with this computer, window is not recognising it. By clicking i knew that...
hey Windows 7 stated, first time here in days, nobody ever tells OS.
you are a winner for savvy award 1000
old relic COMPAQ LT.
your LT now has 2 mice, and if you run 2 mice what happens
they try to get in a fight.
we must shut off the mouse pad first.
I guess this mouse is a MS mouse, no mouse name stated.
I shut off the mouse pad in device manager.
look for the USB mouse not, is this unstated mouse wireless, if yes a new battery is now needed. and matching usb dongle.
now plug in the mouse. PC goes DING donng.,
and it loads a driver
be in the internet to W7 can find the driver.
if still dead, go to device manager,
see that mouse there under. mice and other pointing devices
mine shows, HID mouse here.
if missing , plug the mouse into all USB ports 1 by one and listen for the DINGDONGg (means new USB device discovered)
if still fails buy a new mouse, gee barrow one for a day.
if that mouse works , trash the dead one.
you can not have 2 mice at same time or you get into trouble.
the old mouse pad , we had to use disable in device manager to kill it.
on the new HP we have newer driver and it has this.
" tab, automatically disable pad mouse with usb mouse active"
but old ones dont have this
I too hate pads. when the thumb hits the pad, I want to kill that pad fast.
one ebay a 5 pack of mice is $14
a 5 year supply, all mine fail in 1year, the wires snap near mouse inside, easy;
Jun 18, 2017 | Compaq Computers & Internet
On the window where it shows the clock time, it showed error E0 F2. The stove top works but the oven stop from working. All the digital numbers and all keypad entry was not functioning. For the whole time...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). Follow the link for diagrams and illustrations of your specific model.
Oct 14, 2010 | Ovens
I have a Paradise II, had it installed on 10/06 around March of this year one of the motors for the jets quit. We shut the spa down every summer so we did not have someone come out and look at it. Once we...
If this is under warranty call the manufacturer. If it was purchased at a big chain store like cost-co call them. It is very common for hot tubs that are shut down most of the year to have these problems. The motor shaft seals need to stay wet, but when shut down they are dry. When they go dry they shrink, causing leaks, which will in turn let water leak into the motor housing, which will in turn seize the motor bearings. It is much better once you have it up and running to run it year round, and when not in use, turn down the temperature as well as switching the controls over to "economy" Every spa made in the last 10 years has this setting. It will cost $.25 /day to run like this (about) which is way cheaper than service labor and parts. If you have a good spa tech. he should be able to replace the bearings for $35 each plus one hour labor per pump. If you have a bad spa tech. just pay to replace the pumps or do it yourself.
Oct 08, 2010 | Qca Spas Paradise Hot Tub
Savannah Spa Sunset Dlx control pad doesn't respond
What does it mean when the word SPA comes up on the control pad window and locking up the control pad.
May 23, 2010 | Aqua Pool & Spa
Sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
One year old window heat pump unit will not power
Is it not coming on? If it isn't, is the control pad lighting up? Is any of the electronics lighting up? If not, then the control board is probably bad. You will need to check voltages to the control board.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Home Logo
42 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
