Question about Frigidaire Heating & Cooling
Frigidairen Model # FAM18HS2A touch pad locked up and the settings could not be changed but it would still cool. The service dept. had us to kill power to try and reset it and now when powered up it cycles on and off every second, back and forth. Is the problem the touch pad or something else.
  • quha Aug 23, 2010
    I am assuming you are talking about the touch pad PC board. On my parts breakdown it list it as PC Board,display/input. It has a wireing harness that runs from it and plugs into the main PC control board.
  • quha Aug 23, 2010
    I have not corrected the problem. I was asking a question for further confirmation and explanation of your initial answer before I spent the money on a nonreturnable part.
    President:
  • 1,891 Answers
The touch pad is the problem . when you turn the machine off it has to be off for 5 to 10 min before startingagain . this helps the compressor to start . mm
Posted on Aug 19, 2010
  • dennis dodge Aug 23, 2010
    thank you for your feed back .. it's always good to know what corrected the problem . this helps us to help other's thanks again mm .
  • dennis dodge Aug 24, 2010
    i think that the touch pad is your problem / but when you stated that the wiring harness had corrected the problem . i was suprised . but we are not always right . some p c board do come with pigtails or what is a ribbon . the ribons generaly do not go bad but the pc boards do at this point try unpluging the ribbon and clean the end edge // replug it in and retest / often bad connections will cause problems ... . .. you can test the ribbon with a ohm meter . but no mfg gives you the data to do it . you just have to know what your doing . now i am not able to test your board so you are my eye's and ear's . so back to the start if i was to replace a part that is causing the problem it would still be the board . mm .. hope this helps . mm
I can't get my clock set on my GE stove model # JB645DT1BB It said to hold for 3 seconds to change the time but it doesn't change. HELP Please
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing functions
to work properly,The time of day cannot be
changed during a delayed cooking or a delayed
self-cleaning cycle,
1. Touch the Clock pad twice.
For models without a Clock pad:
Hold the + and - pads for 3 seconds.
2. Touch the + or - pads.
If the + or - pads are not touched within one
minute after Step 1, the display reverts to the
original setting. If this happens, repeat Step 1
and reenter the time of day.
3. Touch the Start/On pad until the time of
day shows in the display. This enters the
time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
Clock pad. The time of day shows until another
pad is touched.
http://www.managemylife.com/mmh/owner_manuals/138431/GE-Free-Standing-Electric-1112529L
Sep 19, 2013 | General Electric Stove/Oven/Range Chrome...
Unlockmy lg microwave oven
As with most situations, it depends on the model number, but try this:
To set child lock:
1. Touch STOP/CLEAR pad.
2. Touch and hold 0 pad more than 4 seconds. LOCKED will appear in the display window and oven will beep twice.
To cancel child lock:
1. Touch and hold 0 pad for more than 4 seconds. LOCKED will disappear from the display and the oven will beep twice.
Sep 10, 2013 | Microwave Ovens
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
What is the normal life of the brake pads of a Toyota Corolla 2007 model? my car has run 30,235 kms and the service dept says the brake pads need to be changed.
with modern pads(no asbestos)an average life is about 30km for auto ot 40 for manual.with a rotor change at about 60km for fronts.
Oct 13, 2010 | 2007 Toyota Corolla
THE LOCK LIGHT KEEPS COMMING ON, EVEN WHEN I TURN IT OFF BY HOLDING THE FRIDER AND FREESER BUTTON IN FOR 3 SEC, ALSO NONE OF THE BUTTONS ARE WORKING I CAN NOT CHANGE THE TEMP TURN OFF LOCK ECT
Hi.
Try disconnecting the power cord or tripping the circuit breaker for two minutes.
If that does not fix the problem, please give us make and model number of the fridge, so that we can troubleshoot further.
Regards.
Mar 05, 2010 | Refrigerators
Touch pad problems
Dell has their own utility for the touch pad.. it may be its own icon in control panel
Feb 11, 2010 | Dell (6F858) Cooling Fan
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
The touch pad fades out and now won't work.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 09, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Heating & Cooling Logo
145 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
