Question about Dell Latitude D610 Notebook
Th ebattery light flashes contiuosley from green to orange even when the ac adaptor is plugged in the mains .do i have faulty battery as well as a faulty aadaptor ?
  • 64 Answers
Joanne, remove the battery and unplug the power adapter. Now replug the power adapter and start the laptop without the battery. If all is well then you've determined the fault is the battery. Which is very common on those laptops. -Ravi Shanghavi
Posted on Aug 19, 2010
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
Gateway NV5207u will not power on when the power button is pressed. The Power light does not light up when the battery or AC power is plugged in. Can you help?
Sounds like there is a serious fault in the motherboard. I'm assuming you checked that the AC adaptor is working ok? Check first that there is power to the adaptor and power out of the adaptor by ensuring the green led is on and not flashing, a flashing led indicates power is not making a circuit in the motherboard and therefore a faulty powerboard.
Mar 27, 2011 | Gateway NV5207u Notebook
Battery light flashes orange three times then green. It doesn't impact battery life or operation. Is there a danger I that I might lose all my data? can I safely continue using laptop with ac adaptor...
This indicates either a faulty battery, charging circuit or motherboard issue with the charging port or charging circuit.
You can run the laptop solely on the ac adapter without issue as long as you have steady power. Try removing the battery and plug in the AC adapter and see if the laptop gives you the same light flashes...if it does, you maybe having an AC adapter issue. Try running the laptop solely on the battery and see how long the charge lasts.
Hopefully, all you are dealing with is a battery that is losing a few cells but is still capable of functioning...then you just have to get a new one.
Jun 16, 2010 | Dell Inspiron 6000 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
I have a laptop and there seems to be a light currently flashing orange along the front. Ive searched everywhere to find out whats happened but the laptop won't switch on at all. Its a toshiba Prestege...
The flashing light on the front of your laptop is a low battery warning. There probably isn't enough power in the battery to turn on the laptop. You need to plug in the ac power adaptor and let the battery charge until the battery light turns from 'orange', to 'green'.
May 02, 2008 | Computers & Internet
Dell Latitude D610 Notebook Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
